Recently, I am experiencing a new issue.
The car will run hot, even if it's 8 outside!
Not too hot though. The temperature needle will point to 25mph instead of just above 20mph.
The car will heat up when at higher speeds. Local driving it would cool off. Now it's running a little hot no matter what.
I changed the air filter and noticed no difference. I checked the radiator for blockage, no luck.
Right now I am going to have the radiator power washed in case it's full of salt.
My only other guess is the thermostat is stuck a little closed. I replaced it a few months back.
My fan works fine.
Should the thermostat be next or is there something else I should look into first?
Just in time for my 3,000 mile drive.
