Transmission cooler lines, output and return?
Im installing a trans temp gauge sending unit today and will be splicing into the output cooler line that sends fluid from the transmission to the cooler.
My question is what cooler line is out from transmission and what line is return to the transmission? (when looking at the fittings on the transmission)
Ive searched on here and found only one thread that states the bottom line is fluid leaving the transmission but Im just looking for a quick confirmation. Id hate to splice into the return line and be monitoring cold fluid all the time.
Thanks!
To do list:
