Originally Posted by
dream215
hey... i have to replace two bad ignition coils #6 and #8... an easy job... im just having a hard time finding the order of them... anyone know where i can find a diagram of the exact number so i can locate the right ones to replace it.... thanks in advance
Consider replacing all of them as well as the spark plugs. There are some good deals available on OEM coils from Sparta, a vendor on this site.
The PCM is not infallible when it comes to identifying the misfiring coil. And they tend to be intermittent problems. If two coils have already failed, the others are not far behind. This is a known problem with the original version of ignition coil on these cars.
Lifespeed
