Currently working on a complete write-up, but I'll wait until I return from the track tomorrow to finish it up. But to answer some key questions here and for anyone going forward for the install this weekend, here is some of my findings:
My backing plate did not need to be removed, no clearance issues. I'd guess about 8mm of clearance between the plate rivets and the rotor. I left mine on.
Grinding the caliper mount ears is very minimal and quick. I used a die grinder with a coarse resurface disc, your really just needing to polish off the edge of the ear, I did not remove more than 2mm of material.
The rotor centerbore was slightly more difficult, I used a die grinder with a carbide grinding bit. Go around a few times, then test fit the rotor, if it does not slide all the way on go around a few more times and repeat until it fits. The iron is more difficult to grind away.
Finally a big issue for me was caliper clearance aginst the wheels weights. My outer tape weights hit the fins at the end of the caliper. Two part repair, first grind down the 8 fins on each caliper from the outer edge of the caliper to about 3/4 inch inward untill the fins are flush with the caliper. This grinding took the longest, I used a die grinder with a sanding disc to removed the bulk of the material, then resurface discs progressively softer to polish the visable surface. Also rebalanced my wheels moving the outer weights as far outward as possible.
To come with the write up will be videos of the mounting ear and rotor grinding, and various install pictures.
Post up videos from the track too if you can
Brackets came the other day. Now just gathering the other parts.
Born 03/04
Adopted on 01/03/05
Now Procharger boosted #04
The wheel weight issue is the same as the Baer kit. If you get your wheels rebalanced with the weights in the center of the hoop, they clear. Take a close look at our wheels there is slow point in the center.
2003 DBP/LF - # 36 (sold)
2003 DBP/LF - # 205 (sold)
2004 Black - Trilogy #43
2003 Black - shitbox (sold)
2004 DTR - shitbox #2
But it is less effective to dynamic balance them with the wheel weights so close to each other and will require more weights to be added in that location.
This issue was never mentioned in this thread.
Not to state the obvious, but the ability to locate balance weights as required across the width of the wheel to accomplish a good balance is pretty important.
If the calipers don't clear wheel weights that is a problem.
Lifespeed
Lifespeed
They clear low profile weights, which is what about every tire place carries now
Not sure what low profile weights are but the ones we use at work are not more than 2mm thick probably less. Worst case you static balance (inside edge only) the fronts. On a roadforce balancer you can achieve a decent static balance. Most of my cars that have had custom wheels have been balanced that way with minimal issues.
Neil
2003 Mercury Marauder - SB/LF
Even low profiles are likely to be problematic based on my fitment, and while not as big of an issue as relocating the weights inboard, lower profile weights mean they are further spread out, also reducing the accuracy of the balance, but this is minimal and is only worth mentioning.
You've already got all your tools out for grinding, what's a few more minutes to grind down the calipers?
There are currently 7 users browsing this thread. (0 members and 7 guests)
