Page 71 of 75 FirstFirst ... 2161646566676869707172737475 LastLast
Results 1,051 to 1,065 of 1125
Thread: Big Brakes on a not-so-big Budget? YEP
  1. #1051
    Apr 2010
    South Florida
    All You do is modify the hub a little, so every rotor fits. You'll have to replace the rotors eventually anyways....
  2. #1052
    May 2003
    Wichita Kansas
    Anybody looked at the Cadillac ATS Brembo calipers as an upgrade? Newest swap for the 03/04 cobra guys for a cheap front brake upgrade. Curious if these could be adapter to work on Marauder.
    Joe
    2004 SB
    4.10's and a tune
    More to come
  3. #1053
    Jan 2015
    Mishawaka, In
    Quote Originally Posted by 03MERCMARAUDER View Post
    Joe
    Not sure why, the set that Zach and Jerry have are perfect
  4. #1054
    Jun 2008
    Waukesha, WI
    Because they are 4 piston fixed vs. 2 piston floating.
  5. #1055
    Winston Salem, NC
    Hmmm...interesting...!
    2003 300A
    Eaton Swapped by Curless
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    ADTR Coil Over Suspension
    SW Headers and Exhaust
    Accessories By FastBlackMerc
    4.10 Gears
    Aeroforce Gauges
    Pantherlights Headlamps
  6. #1056
    May 2003
    Wichita Kansas
    Quote Originally Posted by mm svt View Post
    Never said they weren't perfect..... just another option to look at.
    2004 SB
    4.10's and a tune
    More to come
  7. #1057
    The Dirty South
    If it's a Brembo more than likely they will not work. The front spacing will be too wide to clear the backside of the wheel.
    You could use them IF you plan on using a spacer. Which I hate the thought of using.
    I tried a set of Brembo 4 piston calipers from a GT500 and lost $$ trying to make them fit behind a stock wheel. Gave up and went to this setup!
    Good luck, keep us posted on your results.
  8. #1058
    Dec 2014
    Hastings, mi
    Can anybody tell me if the 05+ Mustang wheels clear the calipers? Not the diameter specifically, but the spokes? I had American racing torq thrust 18x9 prior to the brake upgrade and afterwards, the spokes of the wheel hit the face of the calipers. I ended up replacing the wheels and kinda got stuck specifically with a set I'm not overly enthusiastic about. I don't have oems, I know they can clear, just didn't have any. But looking at maybe some mustangs.
    #BSTDMRC #LSSWAPPEDMARAUDER
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
  9. #1059
    Jun 2008
    Quote Originally Posted by cheapthrillb2 View Post
    It would be helpful to know which of the litany of offerings you're referring to.
    I can say with certainty that the wheels seen in this picture do in fact clear the Zack brakes.
  10. #1060
    Dec 2014
    Hastings, mi
    I'm specifically looking at the 05+ Saleen hertigae 19" wheels.
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
  11. #1061
    Nov 2017
    Blue Springs Missouri
    Probably too much for you if your ocd is preventing you from using a round sanding drum inside a round hole for the .001” needed. What do you think the machine shop would do anyway? Set up mill or cnc the rotor.
    I would think a machinist would put the rotor in a lathe since that’s what is used to to turn down inside or outside dimensions usually. But what do I know.
  12. #1062
    Dec 2014
    Hastings, mi
    Quote Originally Posted by a_d_a_m View Post
    Yep, thankfully the saleen heritage knock offs cleared lol.
    2019-08-13_03-49-04 by Cheapthrillb2, on Flickr
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
  13. #1063
    Winston Salem, NC
    Looks cool! Nice!
    2003 300A
    Brake Upgrade
    Mo's Tune
    JLT Intake
    Addco Sway Bars
    4.10 Gears
    Aeroforce Gauges
  14. #1064
    Apr 2019
    Leon County, FL
    This may seem like a stupid question, but since I’m getting ready to install mine this weekend what die grinder attachment did y’all use to open up your hubs?
  15. #1065
    Apr 2019
    Leon County, FL
    Got them on today, wish I had done it sooner. Absolutely love them guys!
There are currently 4 users browsing this thread. (0 members and 4 guests)
  1. $350 budget...
    By dwrwebb in forum Tuning
    Last Post: 04-27-2010, 09:24 PM
  2. Performance on a budget
    By runamuckr in forum Shop Talk
    Last Post: 10-21-2006, 06:21 PM
  3. 300 HP on a Budget.
    Last Post: 12-05-2004, 07:57 PM
  4. Low Budget Rice Boy
    By Donny Carlson in forum The Lounge
    Last Post: 11-02-2003, 05:41 PM
