Page 73 of 75 FirstFirst ... 236366676869707172737475 LastLast
Results 1,081 to 1,095 of 1125
Thread: Big Brakes on a not-so-big Budget? YEP
  1. #1081
    Nothing in a braking system is the truest of true. With that said I would personally drive it until I could tell it was changing sound as in going away or just the slightest bit worse. It would be easier to find it if it worsens.
    It may just need to all be broken in more.
  2. #1082
    Jul 2015
    lemont illinois
    is the clip under the chevrolet caliber installed correctly ? it fits both ways . and if its wrong it makes noise . happened to me .
  3. #1083
    Oct 2008
    Massachusetts
    The pads not reaching the bottom part of the rotor surface is normal I think. My setup has the same wear pattern and I’ve noticed it on others as well.
  4. #1084
    Jul 2015
    lemont illinois
    i dis agree . the pads not only on this set up , but on all vehicles grab the entire rotor . check your rear rotor for reference . by the way , in your opinion does your vehicle stop any quicker ?
  5. #1085
    Jun 2008
    Waukesha, WI
    Quote Originally Posted by marauderrocks51 View Post
    Wrong......
  6. #1086
    Jul 2015
    lemont illinois
    i think you are correct . with out any technical data IMOP its the same .
  7. #1087
    Oct 2008
    Massachusetts
    Yeah, I have to say you are wrong on this one.
    https://www.corvetteforum.com/forums...ficiently.html
    Yes, stopping power is greatly increased.
  8. #1088
    Jul 2015
    lemont illinois
    well thanks for that info . makes the investment in the brakes more palatable . they are on now and it is what it is . great research . cleared that up .
  9. #1089
    Jan 2019
    Baton Rouge
    Long story short, it was the caliper bracket.
    Now for the long story. I got the red a$$ and ordered a new caliper / bracket and hub assembly, which along with the new rotor and pads would just about rule everything else out, beyond a bent spindle (as nothing was contacting the wheel or wheel weights). The hub assembly arrived on my doorstep first. The existing hub was true (I checked the runout and there was no play, but it didn't have the lubed spring in its step that it should. I installed it along with everything else, and there was no change. After taking the caliper / bracket off in anticipation of the new one arriving, I noticed a very odd wear pattern on the lower portion of the brake pad. I don't have pictures handy but it was the outside of the bottom of both inside and outside pads. I checked the previous set of pads and noticed a similar but faint impression...makes sense as I only drove those a few miles vs. these were driven more.
    Once the new caliper / bracket arrived I compared the brackets and noticed they were not exactly the same...we're talking 1/16" here, 1/32" there, but not quite the same. No part numbers on them but not quite the same. I installed the new bracket along with the existing caliper (both out of curiosity and laziness). The caliper now contacted the wheel weights. So the caliper was moved outboard, which I'm assuming corrected the alignment issue between the pistons and the pads. I sc***** the wheel weights off, bolted everything together, and there's been no noise since. I'll be returning the new caliper and old bracket to Autozone. I've probably done several hundred brake jobs in the past but this one was the most frustrating. I'll need to get the wheel re-balanced shortly, and may grind the fins on the caliper down first. I had that thought once I saw it contacting the wheel weights but I couldn't help myself...needed to see if that was the fix.
    So as previously mentioned this wasn't meant to question the swap nor did I want to encourage anybody to. The pedal feel is great, the car stops on a dime, and ^(@&#(&@#$ it just looks cooler.
  10. #1090
    Jan 2019
    Baton Rouge
    The third / top clip was not included with either the new calipers or the two new pad sets. I did buy a C5 hardware kit while at the parts store so I have two. I do need to take everything apart ONE MORE TIME to put loctite on the caliper bolts. When I do that I'll install those. Since I addressed the other issues described above, I haven't noticed any noise though I've only driven the car about five miles of light city driving.
  11. #1091
    Oct 2008
    Massachusetts
    Quote Originally Posted by MercLSU View Post
    Glad you got it figured out!
  12. #1092
    Feb 2005
    DC MD Area
    I recently did a big brake upgrade on my car. Check out the video links below that gives a pretty good step by step of the process.
    https://www.instagram.com/tv/B-QqwdOBdwW/?utm_source=ig_web_copy_link
    https://www.instagram.com/tv/B-Vs5JT..._web_copy_link
    2003 300A Black MM
    FRPP ALUMINATOR MOTOR 10:1
    STAINLESS WORKS LT HEADERS
    ADDCO FRONT & REAR SWAY BAR
    MONROE HD QUICK STRUTS FRONT
    QA1 ADJUSTABLE REAR SHOCKS
  13. #1093
    Apr 2020
    Sacramento
    Can someone please provide me with the eBay link to purchase the adapter brackets? Thanks
  14. #1094
    Quote Originally Posted by Javonys View Post
    Post 1...
  15. #1095
    Nov 2006
    Langley, BC
    Question C4 or C5 calipers?
    When I link to the Napa calipers on the kit list, it shows them to be a C4 Corvette, 97-2004. Is that wrong? You said you used C5 calipers.
    I was literally just ordering the calipers, I have all the other pieces.
    MOD HISTORY:
    -Lidio's Xcal2 flash, JLT CAI
    12.81@107.78 Oct 02/09
    -Ventilated Block Mod
    Out of commission
    -Rebuilt with:
    -Widened rims
  1. $350 budget...
    By dwrwebb in forum Tuning
    Last Post: 04-27-2010, 09:24 PM
  2. Performance on a budget
    By runamuckr in forum Shop Talk
    Last Post: 10-21-2006, 06:21 PM
  3. 300 HP on a Budget.
    Last Post: 12-05-2004, 07:57 PM
  4. Low Budget Rice Boy
    By Donny Carlson in forum The Lounge
    Last Post: 11-02-2003, 05:41 PM
