Results 1 to 4 of 4
Thread: Power Window Switch disassembly
    Friendswood, TX
    I've got a couple of buttons on my master switch that are not making good contact and have taken the switch out to clean the contacts. I've got switch assembly separated from the back half of the case with the plug guides on it, but how do I get the switches out to clean the contacts? I see the four tabs that look like they hold the top half to the bottom half of the switch assembly, but even when I have them disengaged it seems like something else is holding it together. I'm trying to be gentle and not tear it up. Do the switch caps pop off first? I know many of you have done this before so I'm looking for your help.
    I did search but didn't find any pics of the disassembled switch, even though I thought I'd seen them on here before.
    Oct 2005
    Southwest Florida, Lee County
    Easier and better to replace the assembly. The aftermarket has them and it is cheap! http://www.rockauto.com/catalog/more...358&cc=1428218
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    Yes the buttons pop straight off. I clean mine every couple of years and it takes all of 10 minutes. Super easy.
    You will see black in the contacts that are inop, I just use my dremel and buff them clean, may even tweak the trip assembly/rocker a slight bit for improved contact.
    "Since 2004"
    Jun 2010
    essextrash, maryland
    "Since 2004"
    Yep! Why buy new when theyre easy to clean. Ive done mine a few times, i used a file from a leathermans tool. Rubbing alcohol or electronic cleaner should also clean them up. They may be cheap to replace, but why spend your hard earned money on something you can easily fix?
  1. Removing Power Window Switch Trim
    By cat in the hat in forum Interior Electrical/Electronics
    Last Post: 05-15-2013, 04:17 AM
  2. Wanted To Buy Needed, Power window master control switch trim piece
    By Gordy in forum Marauder Parts/Misc. Wanted
    Last Post: 08-22-2012, 02:14 PM
  3. Power window switch
    By blackrauder in forum Marauder Parts/Misc. Wanted
    Last Post: 05-05-2009, 10:48 PM
  4. Master power window and power mirror switch
    By Dobs in forum Marauder Parts/Misc. Wanted
    Last Post: 04-27-2009, 10:18 AM
  5. Window Switch
    By 03blackmerc in forum Welcome Forum
    Last Post: 01-13-2009, 07:17 AM
