Results 1 to 15 of 30
Thread: Battery Cable Change, Looks like fun!
    Oct 2014
    Cunningham, Kansas
    I have an issue with my 2004 SB. One of the previous owners cut the positive battery cable off and used one of those cheap a$$ clamp on terminal ends. The proper Marauder battery cable part number 3W7Z-14300-CA is no longer available and nowhere to be found. I reasoned that a 2004 Mercury Grand Marquis cable should be similar (part number 3W7Z-14300-AA). I ordered one from Tasca Ford and received it today. The cable looks identical except a couple of the mounting tabs are not in the exact same place. The negative cable is included as part of this cable assembly.
    I crawled around under the Marauder today to see where the cable attached to the starter and my replacement cable has the same connections. I am guessing that these cables may be the same other than the locating tabs that fit onto the cam cover bolt threads. I will be an easy fix to move them. My problem is that I am not sure what is involved in removing the part of the cable that comes up behind the engine from the starter and I don't want to cut the cable to remove it as I am not 100% sure the new cable is exactly the same length.
    Any help or advice would be appreciated. I am currently not having problems with the existing cable, but want to change it as it is a problem waiting to happen. I may wait till spring to tackle this as today is the only good warm weather day left and I don't want to get it tore apart and have to finish when it is cold outside.
    Pictures to follow.
    https://lh3.googleusercontent.com/-k...129_111447.jpg
    https://lh4.googleusercontent.com/-8...129_111427.jpg
    https://lh5.googleusercontent.com/-X...129_111539.jpg
    https://lh5.googleusercontent.com/-9...129_111419.jpg
    Bob
    Jun 2007
    Whitehall, PA
    I bought the last available one in the country 3 years ago because my trilogy's harness was screwed up beyond repair.
    Its not that hard to change, I did it outside in 30 degree weather in about an hour.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    Jun 2007
    Whitehall, PA
    I should have read the whole post.
    I'm sure I don't have to say it, but disconnect the battery terminals first, Then disconnect the starter and then the bracket on the back of the head.
    If its a nice day you might want let the harness lay in the sun for a while so make it more pliable. It's really a straight forward job and I have heard the CV/ MGM harnesses are the same as the MM except for the cam cover clips.
    Oct 2014
    Cunningham, Kansas
    Thanks I was really hoping someone would reinforce my guess that the wiring part of the cables is the same on the CV/GM as the MM. Uhhh, disconnect the battery cables?? Well I suppose there are people dumb enough to try it with them connected, but I am not one of them.
    Thanks
    Bob
    Removing the wiper cowl isn't necessary but yields a TON of space behind the engine and I almost consider it "step 1" to most repairs.
    "Since 2004"
    May 2009
    Moreau Island
    "Since 2004"
    Also by doing so it provides a good opportunity to clean out all the gunk that settles in there.
    Jun 2007
    Whitehall, PA
    Quote Originally Posted by Fastbob View Post
    Thanks
    Bob
    I only said about disconnecting the battery because sometimes people get excited to work on their marauder and forget this step..... I've been guilty before
    Jul 2012
    Seattle Washington
    Yes the GMQ cable is the same exept the valve cover mounts.
    Oct 2014
    Cunningham, Kansas
    I am thinking I can reach the retaining bolt on the back of the head from below, but not sure. I will wait till next weekend and if the weather cooperates I'll set up my Maxx Jaxx lift and tear into it.
    Mar 2003
    Las Vegas, NV (Henderson)
    I've changed 6 battery cable sets on Marauders over the years. The cable is the exact same as the MGM one. Just carefully release the plastic tabs. They are basically zip ties around the cable so I use a small flat balde screw driver to release the lock tab and remove the plastic reatainers. The one up by the alternator is just taped to the harness.
    The nut on the back of the right head is 13mm wide flat nut. I found a flat ratchet works great to get to it from the underside of the car. You have to do it by feel.
    Pre bend the new cable assembly to roughly match the old one for ease of installation. The only area to watch out for is where the cables run under the right head along the block right near the starter. Make sure the cable does not touch or is near the exhaust manifold. (By the way, this is the area almost all the MGM/Marauder engine fires start at.) It's tucked up next to engine pretty close in this area.
    Use care when removing the 10MM nut on the end of the power junction box (one end of the red cable attaches here on the engine side of the big black power jucntion box). It's a locknut and it's easy to break the plastic. I hold the end of the old cable with a pair of pliers and then loosen the nut after spraying some penatrating oil on the nut.
    The wires only connect one way, so no chance of making a wrong connection.
    1 of 111 Without Heated Seats
    6 CD Changer in Trunk
    Locking Lugs
    Trunk Organizer
    Marauder Side Emblems
    Rear Bumper Inserts
    Nephews: Blue w/Light Flint
    Born 02/05/03
    2011 of 7838
    Locking Lugs
    Trunk Organizer
    Factory Alarm
    Rear Bumper Inserts
    6705 of 7838 2003's
    Built Friday 02-07-2003
    Bought 09-10-2012
    #5 2003 DBP/Light Flint
    6741 of 7838 2003's
    Built Tuesday 02-11-2003
    Bought 05-06-14
    Good reason to do the Big 3/4 upgrade and change the starter cables as well if they are iffy.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Oct 2014
    Cunningham, Kansas
    Okay, I give up...what is the Big 3/4 upgrade?
    Oct 2014
    Cunningham, Kansas
    Quote Originally Posted by vegasmarauder View Post
    Pretty much the way I was thinking it would go. I did NOT know the cable nut at the power box was a locknut. Thanks for letting me know. Maybe do it this weekend.
    The Big 3 is a simple electrical upgrade for any vehicle to improve a better electrical charge from the alternator to the battery. Your stock electrical system consists of 3, or more, wires hence the term “Big 3”. These are the main wires for your electrical charging system. The actual “upgrade” is we are adding a thicker gauge wire to the system.
    The 3 wires are:
    - Positive from battery to positive from alternator
    - Negative from battery to ground
    - Engine block to ground
    Also the Positive from the battery to the main relay/fuse block is another wire that is usually upgraded so really it's the Big 4. But the other 3 wires are the main ones that are focused on.
    Most who do it are car stereo guys who run big systems but it can be done on any vehicle. The stock positive battery/alternator wire is a 6 AWG wire, by increasing it's size to a 4 or even 1/0 AWG wire you decrease the resistance in the wire and power flows easier. Several or members on the site, I have all the stuff to do it but just haven't felt like doing it yet.
    300B
    Exhaust by Greg
    Oct 2014
    Cunningham, Kansas
    The 3 wires are:
    Sounds like there is a bunch of crimping / soldering involved and the use of a car stereo type multi-connection battery cable end. I would rather have the factory made connections since I don't plan any powerful stereo ("sound system" for you young guys) upgrades. I do appreciate the info.
    Bob
  1. Quick question on the battery cable
    By tylerdurden2816 in forum Shop Talk
    Last Post: 09-16-2014, 01:46 PM
  2. Replies: 10
    Last Post: 02-26-2013, 11:10 AM
  3. Battery cable guage
    By bugsyc in forum Shop Talk
    Last Post: 10-17-2011, 11:53 AM
  4. Battery cable/altenator connection question
    By BlkMamba24 in forum Shop Talk
    Last Post: 08-12-2011, 08:35 PM
  5. Battery cable clamp bolt and nut
    By jimlam56 in forum Community Discussion
    Last Post: 12-22-2006, 09:52 AM
