Results 1 to 15 of 30
Thread: J-MODed Valve body on Ebay !
    May 2013
    Saudi Arabia
    Smile J-MODed Valve body on Ebay !
    Hello guys,
    What do you guys think of this Valve body ? it has a J-mod done to it.
    I want to buy it to install it in my 2003 MM because in my area there's no one can do this mod as I know.
    So I need your advise guys should I buy it or not
    Thank you.
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Oct 2010
    Michigan
    I wouldn't trust it. I would highly recommend doing the JMOD yourself. If I can do it, you certainly can!
    It requires a drill, a drill bit, and 3rd grade equivalent reading skills to do a Jmod.. If you can remove a valve body, you've already done half the job!
    Builder Of Badassery
    Dec 2014
    Saint Clair Shores, Michigan
    I wouldn't buy a used valve body to begin with.
    2005 Mercury S55
    Saleen Supercharged 2V
    May 2013
    Saudi Arabia
    Thanks for your supporting replay guys.
    But I watched the official J-mod video and hell no I cant do that !!!
    I don't know how you guys doing it without putting the gear DOWN.
    It's really hard for me to do it
    I guess it's a bad idea to buy a used one huh !!
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Feb 2009
    Upstate NY
    Quote Originally Posted by BeeDamn View Post
    Yes, don't buy used.
    Just print out the jmod instructions, bring to a transmission shop that knows how to rebuild a Ford 4R70W.
    Buy an aftermarket tans pan with a drain plug too and bring it with you.
    Can't imagine them charging more than 100 to do it.
    03 300A - Number 1727
    I can get you a separator plate and gaskets, modify it and send it to you. You'll need someone local to install it and do the rest of the j-mod.
    I wouldn't trust an unknown eBay piece, but fastblackmerc I would trust all day long.
    Sep 2006
    Clermont Florida
    Quote Originally Posted by babbage View Post
    He's in the Kingdom of Saudi Arabia. Prolly not a great selection of Ford 4R70W tranny shop specialist.
    True but there are alot of "panther platform" vehicles in K.S.A.
    He also has a po box in Delaware to send stuff to, so no worries of overseas shipping and customs.
    May 2013
    Saudi Arabia
    Thanks everyone for the effort.
    So if I got a j-mod plates what else remaining to do the job ?
    The drilling is easy I guess but the rest of the job is difficult to do my self
    I'll try to find a good trans mechanic and ask him if he can.
    IIRC no need to drop the trans right ? just the valve body correct me if i'm wrong.
    Thank you
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Thank you
    Did you watch the video?
    May 2013
    Saudi Arabia
    I watch it maybe ten times also I download it in my workplace to watch it in break time, but I don't know why it's too much for me to do it. The video explanation is so good and clear but I guess I need to practically see it better than watching it!
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Off-Shore America
    I am sure the KSA has a tranny dude around. From YouTube;
    http://www.youtube.com/watch?v=gbIAK...e_gdata_player
    Personally, I dislike this video. Volume is inadequate, and he begins by thanking two people. Just two.
    What about some thanks to Jerry Wroblewski?
    Anyway, hope this helps, good luck!
  1. Manual Valve Body
    By JBFTech in forum Transmissions
    Last Post: 03-07-2013, 03:16 PM
  2. BC valve body question
    By stryker in forum BC Automotive
    Last Post: 04-12-2011, 10:34 AM
  3. J moded valve body kit's
    By WPG_Merc in forum BC Automotive
    Last Post: 04-03-2010, 11:23 AM
  4. Which shift kit/valve body to buy???
    By USMCmarauder in forum Transmissions
    Last Post: 04-02-2007, 10:25 AM
  5. Mach 1 Valve Body?
    By Marauder.45 in forum Transmissions
    Last Post: 05-04-2006, 10:09 AM
