i thought I would try this section to continue my troubleshooting as I'm still struggling.
Symptoms:
Brake lights and blinkers not functional, flasher blows fuse #22 after a few cycles, park safety switch will not unlock after starting car. Side marker lights still work with blinker switch, headlights and wipers all fine.
What I have tried:
New brake light switch, did not change connector. Tested multi function switch on steering column which tests out fine following procedure posted on pantherbb forum. Wiring to the connectors on MFS are grounded out. All but three are giving tone to ground on steering column.
What would you recommend to find the short to ground? I'm ready to throw in the towel and bring it to the dealer but I hate the idea of them ripping into my wiring harness all over the car not ever knowing what could be "affected" down the road.
