Results 1 to 15 of 23
Thread: New fuel rails
    Jun 2015
    MA
    New fuel rails/injectors
    I'm not having very much luck finding fuel rails. Really the only ones and come across are the professional products blue anodized aluminum versions.
    Aeromotives from a 96-98 Cobra work well
    Jun 2015
    MA
    Thank you though those are a little more then I'm looking to spend right now.
    Also if I get new injectors do I need the adapter harness?
    Jun 2015
    MA
    Any other opinions?
    I was thinking of getting a new fuel rail as well. I would like one that can dissipate heat with some cooling fins. Does anyone make a direct bolt in?
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Quote Originally Posted by beanbag View Post
    Any other opinions?
    Those are the cheapest option available.
    Quote Originally Posted by Mike M View Post
    Not much heat can be dissipated atop a running engine in a returnless system.
    Just by switching to aftermarket rails with a larger diameter will keep the fuel a little cooler just by the increased volume of fuel on tap at all times.
    Switching to a return setup with a fuel cooler on the return side would be your best bet
    Not ready for the return less commitment yet.
    Anyone make a bolt on rail?
    18psi pulley
    Billet Oil Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    NO. 567890
    NO. 567890
    Is that a alien code?
    18psi pulley
    Billet Oil Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Washington DC
    Merc's Garage
    Quote Originally Posted by merc View Post
    Is this what you have installed?
    18psi pulley
    Billet Oil Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Washington DC
    Question
    I have the FORE version of the rail before leathal performance bought them out.
    Merc's Garage
    They don't do anything for heat dissipation.
    Dec 2009
    dayton
    oh so correct.
    The stock rails are sufficient to the 600rwhp range, no need to upgrade if you're below that point.
    But what I really want to know is do they bolt on or do they need modification.
    18psi pulley
    Billet Oil Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
  1. For Sale fuel rails
    By na svt in forum Marauder-specific Parts for Sale
    Last Post: 07-16-2012, 07:02 AM
  2. fuel rails.
    By Seneca in forum Shop Talk
    Last Post: 09-24-2011, 03:50 AM
  3. Fuel Rails
    By saxman in forum Shop Talk
    Last Post: 03-28-2011, 02:45 AM
  4. upgrading fuel rails
    By John Nero in forum Shop Talk
    Last Post: 01-08-2010, 01:50 PM
  5. Fuel rails
    By Mr. Man in forum Shop Talk
    Last Post: 11-23-2009, 07:13 PM
