Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Cooling System Burp Procedure
  1. #16
    Really? No takers? Not a single "ask yer sister" or "bend over, I'll show ya"?
    How 'bout a TWSS!...?
  2. #17
    I bit my tongue. I wouldn’t be able to stop... Where’s Joe? He should have a better answer on sticky things.
  3. #18
    Smithfield, Virginia
    No doubt, he would have a totally inappropriate picture of both "burping your system" and "sticky".
    WIN WIN!~ Zack
  4. #19
    Thank you.. I tried it yesterday and so far so good.. the heater is heating and the Marauder looks like is not overheating. I just need to do the last step and hope is all good.
    Thanks again,
    J
    Sent from my GM1917 using Tapatalk
  5. #20
    Apr 2020
    Glendale AZ
    So I did this a couple days ago, in addition to replacing my water pump and thermostat, and I ended up draining about a gallon and a half and putting in 2.25 gallons. I guess whoever had my car before me didn't bother with this, and that's probably why my temp gauge would occasionally rise a bit, which is why I replaced the pump an thermostat in the first place!
  6. #21
    Apr 2015
    Maryland
    I had a lower radiator hose that was leaking and this thread really helped me out, I basically had the front end up quite a bit. I rolled the car off the lift and had the front tires on the ramp going onto the lift. It was a success, a few hours later I added about 8 ounces of coolant, and then a few days later about 4 ounces of coolant. I checked it a week later and I have not had to add any coolant.
  7. #22
    Aug 2016
    Montgomery, AL
    I’m in need of help removing the cross over plug. Seems to be seized up!
  8. #23
    Heat, will need new o ring.
  9. #24
    Quote Originally Posted by itsgreenmoney View Post
    Or if you haven’t rounded it out yet it’s surprising just how handy a Milwaukee 1/4” impact is at knocking a little corrosion loose.
  10. #25
    Apr 2010
    South Florida
    Channel Locks worked everytime for Me.
  11. #26
    I can get you a stainless steel replacement with a hex head.
    PM me.
  12. #27
    Dec 2020
    Los Angeles California
    I did this procedure and I was only able to get about 1 and 1/2 gallons in. When I drained it I probably got about 3 and 1/2 gallons out. Did I do something wrong?
  13. #28
    Apr 2010
    South Florida
    Quote Originally Posted by Pantera View Post
    I always let the car sit over night and refill from the cross over tube till full.
  14. #29
    It also helps if you have the front of the car lifted.....front wheels on ramps, up on jackstands or in my case, an inclined driveway.
    That helps to purge all the air out of the COT fill pipe.
  15. #30
    Jun 2008
    Waukesha, WI
    Squeeze all the hoses too
  1. Good Shop in Houston - burp cooling system
    By JRT_HOUSTON in forum Shop Talk
    Last Post: 12-02-2013, 07:41 PM
  2. coolant system burp
    By tallpaul in forum Shop Talk
    Last Post: 12-28-2012, 10:52 PM
  3. cooling system problem
    By MMcactusflower in forum The Lounge
    Last Post: 10-10-2012, 05:25 PM
  4. Cooling system down
    By Shora in forum Shop Talk
    Last Post: 08-14-2008, 07:36 AM
  5. Cooling system question
    By Fourth Horseman in forum Shop Talk
    Last Post: 02-04-2004, 03:52 PM
