You shouldn't be taxing your system that much with just 400W.
In a perfect world you should only be adding 27-33A extra on your system. (100% output & effeciency) Which at cruising speed shouldn't be an issue.
With an eaton swap the Big 3 should be done before you add any extra electronics.
I found them infinity refs in Amazon years ago for $40 a set. Put them in the old car. Sound was slightly better than factory with the audiophile hu at high volume
Adopted 3/31/11. Sold
03 300a black #1199
TERMINATOR SWAP
430rwhp. Done by mo's
How?? When the car is running your alternator is what keeps your voltage at ~14V. The dimming occurs when your alternator can not keep up with the current demand from electrical system and the voltage drops to the resting voltage of the batteries (~12.6V)
Adding a second battery won't do anything to stop the lights from dimming because it will still be the alternator that it be overwhelmed from the current draw.
Do you know if your power/ground wire is OFC (oxygen free copper) or CCA (copper clad aluminum) wire? Where is amp ground where connected to?
Help? Yes. Fix? No.
Yep.
Big 3 is great for any vehicle, stock or modified. A 400 watt amp shouldn't be dimming the lights unless the power wire is garbage and/or the ground just isn't sufficient enough. I would relocate the ground to a better spot before doing anything else first.
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
Component all the way. The stock stereo powered the infinities I put in just fine, but once I did an aftermarket deck with more juice they really came alive.
Matt H.
(sold)2004' SB, 268rwhp/295tq
2017 F-150, 5.0
2013 SHO DIB Performance Pack
There is no deck on this planet that even compares to about 300 watts of good clean power from an amplifier to a decent set of components in the front doors. You won't even need rear speakers.
Neil
2003 Mercury Marauder - SB/LF
Pick up the first piece of the puzzle today. Got me the JL Audio C-525 components for the front doors.
2003 Marauder... the gentleman's hot rod.
You know what I like best about most people? Their dogs.
