Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Blower's.... what is best?
    As the title says, I'm getting ready to pull the trigger, my question, being a newb and all, I am looking to do an Eaton Kit or the Lysholm Twin Screw kit. I am not considering anything else, those are the choices.
    My MM is for the most part stock, low miles (16k), SW headers/cats, CAI, and a tune.
    Which will do me the best and why, I know which way I am leaning, but I want to know from those in the know and have the real world experience with these that I don't.
    Post up and help a brother out....
    i belive the TS is sugjested for built motors only.
    i do have a cobra short block if you do really want the TS
    Well, after I grenade this motor, I was considering a forged longblock.
    lol i wouldnt do it that way. it may end up costing you more then if you upgrade the motor at the same time.
    Well if you are wanting Eaton call Jerry Barnes, a Lysholm Twin Screw kit, would be ok, up to about 450 RWHP after that then you are rolling dice any thing after that. I my self like this.
    Aug 2008
    Marauderville MD
    Get a eaton kit keep the boost between 9-14 psi and you will have more than enough to get your rocks off
    2004 DTR Mercury Marauder
    Build date:8/18/03
    Delivery date:8/14/08
    #21 of #983 DTR's
    #51 of #3213 in 04'
    And im not spanish my friends just say i look it the names "Michael"
    Quote Originally Posted by DTRMiguel View Post
    Fat people dont get kidnapped
    Zack Tune
    JLT DTR Cold Air Intake
    1/4 Mile ET 14.202
    1/4 Mile MPH 99.13
    Jerry makes a great kit, I think Gregg likes his as well.
    Lehigh Valley, PA
    Dont go over 9-10psi unless you want to repeat trilogy #33's downfall at englishtown.
    2063/3214
    5377/7838
    Uhhhh, yeah, saw those pics. I almost bought that car, then I figured I would buy one that was un-molested.... and keep it that way, that lasted 6 months.
    Anyhow, not looking for any track action, just want that extra oooomph to pass, merge, embarass performance cars etc..
    In all seriousness, this car is just a occasional driver, I just want to make sure I can back up Marauder heritage should the need arise.
    Jun 2005
    East Lansing, MI
    you should just get the eaton kit if that's all you want. It can deliver a lot more than you are wanting.
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    An eaton is proven performance and will do you no wrong. I drive mine in all weather! I don't care if its -10 to 115 degrees with the a/c on full blast, I have raced it in 50 degrees and 100 degrees and never once ran hot. The caracteristics of the car don't change at all, unless you want to pass some one.
    Mine is so well mannered that if i have to drive in the snow so be it. The Lysholm kit looks to be even more impressive but is it needed? You can swap down to a 2.8 pulley on the Eaton (if forged) and have quite the monster. If i could do it all over again i would not change a thing.
    With either kit you will no longer recognise your car. There will be one additional purchase that you will have to make.............Drag radials!!!
    My 12.92 was acheived with a stock pulley, flowmasters, and a k&n drop in w/MT Streets, thats it. Not shaby for out of the box power, just think of all the room to build on when i feel i need some more.
    I am also still running the stock trilogy chip untill i get a real dyno.
    Hawaiian Islands
    You can't go wrong either way...
    They both ROCK!
    ALOHA
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Smoke Cloud
    Get the base trilogy kit and be done.
    The KING of BLING!
    BOOST GETS YOU IMPERSONATED!
    Dec 2007
    You don't need forged internals if you keep the stock pulley/ boost level that is provided in the Twin Screw kit.
    If I'm not mistaking the Eaton kit makes 380- 390hp and the Twin Screw makes about 430 + allot of torque. With the same boost pressure. Seams like an easy choice to me.
    Off course you can change the pulley on the Eaton and make more hp.
    But to me it seams like it would actually be safer to run the lower stock boost pressure off the Twin Screw verses a smaller pulley and higher boost pressure which is needed to make same amount of power with the Eaton?
    And by the way I love my Twin Screw! The power and response from the engine at any rpm is amazing. Plus the sound, looks, quality is also amazing.
    Dec 2004
    plymouth, mn
    The level of engineering and quality of the Trilogy kit is great! It has been my daily driver for 2 1/2 years. It runs great from -15F to 105F. If you mechanically incline do the self install, you will appreciate it even more.
  1. backpack leaf blowers
    By whd507 in forum The Lounge
    Last Post: 12-06-2008, 06:21 AM
  2. Custom Drivers Side Idler 4 Snail Blowers
    By Zack in forum Shop Talk
    Last Post: 05-27-2008, 06:43 PM
  3. Used Trilogy Blowers
    By crouse in forum Shop Talk
    Last Post: 01-31-2008, 06:28 AM
  4. lookin/Trilogy blowers for f-150 web sites?
    By hotford in forum Trilogy Motorsports
    Last Post: 11-08-2006, 08:36 AM
  5. Trilogy Marauders and Rauders w/ blowers
    By metroplex in forum Shop Talk
    Last Post: 03-09-2004, 02:28 PM
