It took until about 35k miles for my 300A to start the startup puff of smoke, but now at 41k it does it noticeably. Also, this car used to go 6k mile oil changes with absolutely no oil consumption, now it used about a half quart in about 4k miles. Although the general concesus on this board re: the 300A smoking/oil consumption seems to be "leave it alone", I am not okay with this engine showing this sort of deterioration at such low mileage, even if it is only nuisance-level deterioration to some people. I am willing to spend the money to properly fix the engine.
My understanding is, and correct me if any of this is incorrect:
Cause:
lack of sufficient cooling for driver's side head
Result: accelerated valve guide wear on driver's side head, causing oil to be drawn through enlarged clearance between intake valve and guide
Repair:
Remove driver's side head, have new guides installed at machine shop
Preventative measures to ensure this does not happen again: Install Reinhart rear cooling mod
Is my understanding correct, and has anyone actually had their head reconditioned at a shop? If it is only the drivers side head that thas the guide wear issue, then I guess an alternate plan might be for me to find another 40k mileage used passenger side head and put it on the driver's side of my car, with a rear cooling mod
PS please don't reply just to tell me you don't have start up smoke on a 300A. I am interested in the proper fix once it has begun, which on my car it has. Thanks
Steve
