Results 1 to 15 of 22
Thread: Best S/C belt
    Rockford
    Question Best S/C belt
    I heard a wierd noise leaving therapy yesterday.
    It started a couple minutes after I filled it with fuel.
    Turned out to be the supercharger belt fraying ,the loose tail slapping the crossover tube.
    I had no tools to either trim the piece or take the belt off.
    I drove it home , carefully in another minute it broke off ,
    On its own.
    I got about 8K on this belt.
    Others have lasted much longer, despite much drag racing.
    I was wondering what your experience with belts is.
    What brand / type have you been satisfied with ?
    Blog Entries
    2
    Gates Fleet Runner a/k/a Greenback.
    I believe Gates has come out with a line of performance belts.
    It maybe something other than the belt.
    Jun 2005
    long island ny
    i went through 2 or 3 belts each time i went a bit shorter. i now have a delco.gates didnt have the size i needed so far so good.
    Feb 2012
    harrison twp,mi
    Quote Originally Posted by Bradley G View Post
    I heard a wierd noise leaving therapy yesterday.i know what you mean with trump and all
    On its own.
    gates fleet runner green ftw. 20k miles on the current one. pulley alignment will play an important roll in belt life. i've even seen wwear on aluminum pulleys from poor belt alignment.
    they even came out with some blue ones in the same material just not in our sizes
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Dec 2009
    I can't get over the green color. I'll give up longevity for a nice black belt.
    I have a Gates on now and a new Gatorback in my toolbox of spare parts and tools I keep in the trunk. These cars are getting old so a toolbox and some essential spares is a must.
    Quote Originally Posted by tbone View Post
    +1
    Tool box, spare belt, quart of oil, gloves, wipes, small hydraulic floor jack and some other parts.
    Gates green stripe is the best. Very little stretch.
    Gatorback is horrible. Like a rubber band.
    Sep 2015
    Mississippi
    Blog Entries
    2
    Yes, Yes,Yes and Yes.
    Something isn't right if all your getting is 8,000 miles. I put at least 30,000 on a cheap Dayco belt before swapping pulleys and it looked to have another 30,000 left in it.
    I'm with Tom on that fugly green. I had it a short time before ditching it and going back to black.. Thump tensioner had no issues keeping it tight.
    Oct 2010
    If you run the green back belt the coating wears off eventually.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    The ones I have used just have a thin green stripe. Barely noticeable.
    Rockford
    I do have a wobble in the lower pulley hub.
    Maybe need to have that balanced better with an adjustment ?
    I have a Thump tensioner as well and have not incurred any slipping.
    I had a green one at one time , I couldn't care if it was pink , just don't want to deal with maintenance stuff so often.
    QUOTE=justbob;1531070]Something isn't right if all your getting is 8,000 miles. I put at least 30,000 on a cheap Dayco belt before swapping pulleys and it looked to have another 30,000 left in it.
    Sent from my iPhone using Tapatalk[/QUOTE]
    Mar 2014
    il, Chicago
    What Jerry said , check pulley alignment
    Vin: 2MEHM75V63X615175
    Build Date: 6/10/2002
    Serial#: 995 of 7839
    995 of 7093 Black
    Accel coil on plugs/Autolite 104s/ K&N intake/Flowmaster 40s/Powdercoated goodys/
    LED Grille scanner/BIGCARSFOREVER Dead pedal/SCT Tune/BBK Power Plus twin blade 65mm throttle body
    Dec 2009
    [/QUOTE]
    I'm having a pink one made just for you Brad!
    It takes 2 seconds to change the s/c belt, so not sure what the fuss is about.
  1. belt slippage???
    By 60sec_assassin in forum Shop Talk
    Last Post: 08-04-2007, 03:43 AM
  2. Trilogy S/C failure?
    By carfixer in forum Shop Talk
    Last Post: 07-30-2007, 04:53 AM
  3. Belt Minder
    By rocknrod in forum Community Discussion
    Last Post: 06-05-2005, 04:32 AM
  4. Replies: 22
    Last Post: 01-13-2005, 10:14 AM
  5. S/C for dummies
    By MERCMAN in forum Community Discussion
    Last Post: 10-26-2004, 09:42 PM
