Chocolate Pecan Pie, Apple Pie, Mincemeat Pie w/ Whiskey Sauce and Lemon Squares.
Pie Crust home made with BUTTER!
ps In the event we have to depart each person has been assigned a dessert to evacuate with.
Looks great. Please share some recipes.
Jamaican Rum Pumpkin, Toffee Bourbon Pecan, and Malva Pudding (look it up).
Diabetic coma a little later...
Sweet potato pie
You had me at “mincemeat pie w/ whiskey sauce!” Since no one else here likes mincemeat I usually try and make my own. Looks great!
Svashtar - "You had me at “mincemeat pie w/ whiskey sauce!” Since no one else here likes mincemeat I usually try and make my own. Looks great!"
My Mother used to make it as did her mother and so on. I got my spouse to make it and it used to be I was the only one to eat it.
Now several others also like so my next day supply is smaller...
