Results 1 to 10 of 10
Thread: Axle End Play
    May 2018
    Maryland
    Axle End Play
    I was changing brake pads and noticed what seems like excessive axle endplay. I can move the axle laterally almost 1/4" and there is no radial movement. Does this mean that the clutch pack is worn out? There is some movement with c-clips, but this seems excessive. The traction-lok is not showing signs of slip and will still spin both tires from a stop. Time to rebuild the differential or shim the clips?
    Apr 2010
    South Florida
    When You remove the brake caliper on the rear the axle should have play in and out. Pulling it all the way out towards You locks it in the diff. How many miles on the rear end? Was it ever opened b4? Any gear swap?
    May 2018
    Maryland
    112K, original gears, was opened at some point by Ford. I had a buddy print the Oasis report for me but it's at the office. Whoever was in there forgot to put the parking brake cable bracket back on.
    Feb 2005
    Fort Wayne Indiana
    52 Ford F1 truck (302 V8 WIP)
    58 Pontiac Parisienne
    93 Mustang Cobra (stock)
    03 Mercury Marauder
    03 Lincoln Town Car
    05 Dodge Magnum (Hemi)
    05 F150 FX4
    15 Porsche Cayenne S
    May 2018
    Maryland
    Thanks FW, but that's not the end play I am working with. Mine is lateral, as in the axle shaft pulls out of the housing. Your video shows what I am more familiar calling backlash.
    Jul 2003
    Yonkers NY
    generally what you have to watch for is up and down and side to side. that usually indicates bad bearing and or axle. A small amount of in and out is normal.
    And this is only a issue if your using a fixed caliper such as a Wilwood kit, you can manufacture c clips to eliminate the end play, you’ll need a CNC to manufacture them then send them out for heat treat.
    Trilogy # 192 / T.S. 0012
    May 2018
    Maryland
    Thanks Guys, I'll chalk it up to normal tolerances.
    Jul 2003
    Yonkers NY
    Why is this a problem with a fixed caliper?
    May 2018
    Maryland
    Quote Originally Posted by jaywish View Post
    https://nasaspeed.news/tech/brakes/p...o-do-about-it/
  1. ~1/4" Slop/Play in Driver's Axle
    By WhatsUpDOHC in forum Shop Talk
    Last Post: 04-19-2017, 04:51 PM
  2. 9" axle parts, soon to be Marauder axle
    By lifespeed in forum Shop Talk
    Last Post: 03-20-2016, 12:25 AM
  3. axle or axle bearing
    By burt ragio in forum Shop Talk
    Last Post: 09-26-2015, 02:41 AM
  4. One rear axle shaft has some end play. Uh oh?
    By Stranger in the Black Sedan in forum Shop Talk
    Last Post: 01-19-2007, 09:51 PM
  5. Axle End Play
    By RUSTY in forum Shop Talk
    Last Post: 08-21-2006, 06:32 PM
