Results 1 to 15 of 23
Thread: Coolant Crossover Pipe
    Aug 2003
    FL
    I have a coolant crossover pipe for sale. The finish is nice but not polished. The paint on it is bubbling where the upper radiator hose was attached. $80 shipped. Paypal is ok.
    Current:
    2004 SB
    Sold:
    17th of 3213 2004 Marauders
    9th DTR of 982
    and best of all,
    71st Trilogy
    2003 TR Mach 1
    2012 RR BOSS 302
    2014 RR GT500
    2003 AB Mach 1
    Attention Eaton swap guys!
    Good price, better snap this up if you're collecting parts and haven't got one yet.
    ImpalaSlayer can hook you up with a source to do the mods to it.
    I'm thinking about buying a few of these up and having them changed for eaton use
    Not a bad idea, Dave. That's one of the more challenging items relating to the swap, so there will probably be a market for them.
    I'd pick this up for my Eaton swap, but I don't have the "specs" and a local guy to do the cut & shortening mod.
    Dave, do you have a source to do the coolant tube mod?
    You betcha he does.
    The guy did Dave's as well as mine. But seeing as Dave put the one from his car onto my car to complete the swap on on schedule, I ended up with his, and he ended up with mine.
    Doe any of that confuse you?
    FWIW, the guy does good work. No leaks. End of story.
    I have a local guy right around the corner that does it, I gota make a jig for it so its easier and faster to make them
    Aug 2003
    FL
    I sold it but found another one in my garage. If anyone else needs one, drop me a line.
    Current:
    2004 SB
    Sold:
    9th DTR of 982
    and best of all,
    71st Trilogy
    2003 TR Mach 1
    2012 RR BOSS 302
    2014 RR GT500
    2003 AB Mach 1
    Dec 2007
    from CAMland, now FT HOOD TX (Army life)
    Hey dude! In need of a coolant crossover tube? Do you still have?
    2003 SB Marauder
    production sequence number 6913 of 7839
    color sequence number 3 of 417
    Born date: 3/25/03
    Adopted date: 2/25/06
    Lidio's tune, SS Inserts, Machined Marauder Pedals and Footrest, Aero2525, Custom H-Pipe, Deleted 2nd set of cats, 2.5in piping over axle, Megs 4'' RES Delete tips, aftermarket deck lid spoiler , Custom god's head grille emblem, S-55 tail light treatment (thanks silversurfer03), 265/50 rear, 235/50 front nitto 555's, 4.10's , K&N CAI, GMS coil packs
    -If you're not first, you're last-
    Quote Originally Posted by Granite View Post
    Six year old thread? Really? Long gone
    Washington State
    6 Years to late.
    How does this even happen?
    Oct 2010
    PA
    LMAO!!!!
    No clue, but what's the going rate for a Marauder cross over tube now?
    SEMPER FI From York, Pa
    Apr 2005
    Queens NY
    I have one in stock black or powder coated silver
    Quote Originally Posted by SGT_MERC View Post
    LMAO!!!!
    About $175 depending on condition.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    I bought all of carfixer's COT's
  1. Ck. Your Crossover Pipe for leaking !!!
    By warren in forum Shop Talk
    Last Post: 10-09-2013, 12:54 PM
  2. Need crossover pipe
    Last Post: 09-02-2010, 07:27 PM
  3. Coolant Crossover Tube Replacement
    By cam in forum Shop Talk
    Last Post: 01-10-2010, 08:15 PM
  4. Divorced dual's or crossover pipe
    By joseph in forum Exhaust
    Last Post: 09-22-2009, 11:34 AM
  5. Stock Coolant Crossover Tubes Wanted
    By Zack in forum Marauder Wanted
    Last Post: 08-08-2008, 07:09 AM
