Results 1 to 15 of 15
Thread: Door Window Switch Lighting
    Oct 2014
    Charlotte, NC
    I read the sticky above and was impressed despite all of the images are missing. Lighting went out on one switch in driver’s door recently, switch works fine otherwise. Too much work to remove and replace the LEDs for me as I priced a new switch through Switch Doctor for $20. I’ll wait for a major malfunction in the switch.
    A couple of youtube vids depicting removing and reinstalling the switch were interesting. In one, the guy stated to remove the cover from the front so as to not break the rear tab, although his rear tab had already broken off. In another vid, the guy just picked it off with one hand and tossed it to the side, casually mentioning the rear tab issue as his was already broken off too.
    One of my rear interior lights are out; searching around for info on how to replace the bulb.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    The switch lighting always on when the car was on was a downfall instead of only on when the parking lamps or headlamps are on.
    It is really easy to remove/replace especially if you know to pull on the front part (where the mirror control is) first then slide forward to avoid breaking the tab on the rear part of it.
    Is the rear map light out or does it need to be moved? I often had to just lean back and push it flat cause over time from super firm shifts and exhaust drone.
    The rear map light bulb is a 42 mm festoon bulb.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Rock auto has it too
    2 years still working fine
    Oct 2014
    Charlotte, NC
    Regarding switch backlighting - LEDs are supposed to last forever - I thought LOL!
    Rear map lights:
    I must admit that I haven’t checked it manually, only that when a door opens only one lamp comes on. According to a youtube vid, the entire rear map light assembly has to come out to change the bulbs - looks easy enough.
    Current Garage:
    William W. Purkey
    The door switch lights are tiny bulbs. Not led from the factory
    Rear map lights:
    Usually its the solder points have loosened up enough to break connection or the contact points have a heavy amount of carbon build up and just need to be cleaned.
    Picture below is another member's master window switch I took apart and cleaned up since their lights were not fully working.
    Negative on that, you do not need to remove the whole assembly to replace the bulbs, the front you do but not the rear. Check the one that is out with pushing the side closer to the center of the car up/in to it kinda clicks into place. You can take a small pick tool and there is a very small hole on one side the of lens that you can stick to the pick took in and gentle pry the cover off, super easy.
    300B
    Exhaust by Greg
    Incorrect. They are LEDs. I've fixed enough to know.
    I thought those were bulbs
    Oct 2014
    Charlotte, NC
    Thanks for this. Raining here through tomorrow night - check it wednesday.
    Current Garage:
    William W. Purkey
    Surface-mount LEDs. I had to resolder one of mine a bunch of years ago.
    I get it. I made a mistake thinking they were bulbs
    Oct 2014
    Charlotte, NC
    Thanks for the heads up. Repaired today; bulb is okay. Contacts for swivel housing needed cleaning and the electrical contact tabs slightly bent out to increase tension.
    Current Garage:
    William W. Purkey
    Oct 2005
    Southwest Florida, Lee County
    Both my seat heater switches are burned out (were replaced three times each under warranty), my driver door lock switch is out, and my headlight illumination is out. All this in 50K miles. I'm going to attempt an alternate form of illumination on these items in lieu of replacing the entire switch on each one.
    2004 Mercury Marauder
    2,187 of 3,214
    997 in Silver Birch
    448 with light flint interior
    304 with heated seats
    336 with sunroof
    Oct 2014
    Charlotte, NC
    Quote Originally Posted by BAD MERC View Post
    Thinking your car doesn't like you and/or had issues with its previous owners.
    Current Garage:
    William W. Purkey
    Oct 2014
    Charlotte, NC
    Cool
    Other side of rear seat overhead lamp assembly went out - I'll check it shortly. Driver's window switch started illuminating on one side - I'll take what I can get! Passenger seat heater controls illuminate at night - not so on the driver's side although it does heat up properly.
    Installed a K&N CAI and drilled additional holes into the pan under the air suspension pump - can't hear it anymore! Car rides and parks level so it must be working...
    Current Garage:
    William W. Purkey
  1. Wanted To Buy Drivers Door Panel Window Switch Cover
    By crownvic97 in forum Marauder Parts/Misc. Wanted
    Last Post: 07-25-2016, 11:24 AM
  2. Wanted To Buy Window door switch panel..
    By airjordan2k8 in forum Marauder Parts/Misc. Wanted
    Last Post: 02-03-2014, 07:27 PM
  3. Replies: 1
    Last Post: 08-05-2012, 08:12 PM
  4. Wanted To Buy Driver door window switch trim
    By DallasT in forum Marauder Parts/Misc. Wanted
    Last Post: 05-13-2011, 06:24 PM
  5. Driver's side door/window switch panel
    By Embassy in forum Marauder Parts/Misc. Wanted
    Last Post: 07-17-2009, 05:22 AM
