Mid engine DOHC Ranger!
I was tired off flogging my 3.sl0w V6 Ranger.....so I installed a 5.0 DOHC!
Mid engine of course for proper weight distribution.
Just gotta get good engine mounts that are not made of wood....and those red straps are only rated for @ 300 HP.
Going to mount the KOOKS Headers 'upside down' like a drag boat!!
