Results 1 to 15 of 27
Thread: 2003 Marauder For Sale - 18,300 miles
    The time has come to sell my Marauder.
    I bought her brand new in December 2002.
    MSRP was $35,000+....got her 'on the road' for $30,600 with the year end rebate.
    It is pristine, with a few good mods.
    Just 18,300 miles.
    I just had the OEM 4.6L engine rebuilt with new bearings and rods.
    Wayyy back when (2004), I spun several bearings while drag racing....with under 10,000 miles on the 4.6L engine.
    I pulled the OEM engine, put it in my basement and replaced it with my now deceased Big Bore 5.0L. (split the block....)
    The newly rebuilt 4.6L has steel oil pump gears, ported heads with +1mm valves, Crower Cams ($1,200!), extrude honed intake with plenum spacer.
    Heads were port matched to extrude honed/ported intake. I installed the 'Head Cooling' mod to the back of both cylinder heads.
    Alternator case, front timing cover and upper intake are all powder-coated silver. (they almost look white because of the flash pictures)
    Lower intake is painted Hi-Temp silver.
    Kook's headers with Hi-Flow Cats, X-Pipe and Magna-Flow S.S. 18" mufflers...OEM over the axle pipes and OEM MEGS tips.
    Headers, pipes and Cats were HPC coated silver.
    Transmission has J-Mod valve body, Hughes deep sump finned aluminum pan, and an additional B&M cooler (fan assisted) in series with OEM cooler.
    Rear axle has a SVO aluminum Rearend Girdle, Redline Gear lube; OEM 3.55s
    Rear rims are widened to 9.5" with P295 Nitto 555s and fronts are stock width rims with P255 Nitto 555s.
    Suspension and brakes are OEM/bone stock.
    Exterior has rear spoiler and a 'Pro-Guard under rear bumper along with "MARAUDER" front fender badges.
    Windows are tinted at Maryland legal 35%.
    Interior is spotless, the leather seats don't even have wrinkles!
    Aluminum 'MARAUDER' foot pedals with custom dead pedal. Floor mats are 95% perfect.
    'Some' additional gauges along with dual gauge A pillar.
    If you don't like gauges....you won't like this Marauder!
    Don't mind the missing coil covers...I pulled them off to check the spark plugs and didn't put them back on before shooting the pictures.
    The Marauder is in the Baltimore, Md area.
    Ready to drive home.
    BTW: She still sounds awesome and she still moves!
    I've researched its value and Hagerty, which takes into account rareness and future collectability, has the following listing for a Marauder:
    #1 Condition - Concours : $26,200
    #2 Conditon - Excellent : $19,500
    #3 Condition - Good : $15,600
    #4 Conditon - Fair : $10,000
    I'm asking $19,000 OBO.
    More pictures:
    Brake pedal has "MARAUDER" in the center section.
    The seats don't even have any wrinkles in them:
    The dash gauge pod has Vacuum/Boost and Fuel Pressure gauges...never did get a blower on my Marauder....
    Steering column gauge is Water Temperature
    A pillar gauges are Oil Pressure and Oil Temperature gauges
    Transmission Temperature gauge has 2 senders and a switch next to it.
    You can read the transmission fluid temperature coming out of the transmission (hot) and returning to the transmission after the coolers.
    and more pictures:
    Nitto 555s:
    P295 rear
    P255 front
    I have the 'elephant trunk' sound attenuator...if you really want it.
    I used DEI heat shields on the starter, fuel lines and under the floorpans directly above the Cats.
    The Kooks Headers and H-Pipe have 'Ball & Socket' type connectors to make alignment/bolt-up easy.
    Price reduced....who wants an almost new Marauder that moves!?
    (I need to order my new 2018 F150 Ecoboost with 10 speed trans!)
    Includes Xcal tuner with custom dyno tune:
    More pictures of the underside and exhaust:
    (blue cubes are 'IN/Hot & OUT/Cold' trans temp sensors)
    Hughes Deep Sump, finned aluminum Transmission pan:
    MagnaFlow 18" Stainless Steel Mufflers:
    OEM tailpipes/MEGS tips:
    Price reduced!
    Where are you going to find this nice a Marauder for less than the price of used POS Honda???
    Mar 2018
    Nanaimo bc Canada
    Hi. Joe. Where are you at now in terms of $ for your MM?
    Cheers
    Hiram, Georgia
    Sell it to me for $14,500.
    Quote Originally Posted by vanillagator View Post
    Cheers
    I've got it listed for $20,500....I'd let her go for $20,000.
    Nothing needs to be done to the car other than registering/tags.
    Quote Originally Posted by martyo View Post
    Sure!..... with a $6,000 tip!......
    $19,000....
    May put it on eBay and see what it'll bring.
    $19,000 OBO.
    Got to get a new 2018 F150....help me out here!
    Oct 2014
    Charlotte, NC
    I make positive comments about the cars for sale in these 'Marauders For Sale' threads and they are never approved. Do I have to buy someone off? Are the Russians (?!?!) hacking the board?
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    Cape Cod
    Unless you have first hand knowledge of the car to share with interested buyers, willing to look at a car for a buyer, or are an interested buyer, all comments, GLWS and suggestions are deleted. This is a Classified Section, not a discussion. Plain and simple.
    MOK
    I don't brake for curves!
    Oct 2014
    Charlotte, NC
    Marketplace
    Quote Originally Posted by MM03MOK View Post
    Thanks for this. I now know the stringent rules for posting in Marketplace. Things must have really gotten out of hand to formulate this policy on a 'product specific' discussion board.
    Current Garage:
    William W. Purkey
    I understand the policy regarding posting in a 'FOR SALE' thread.
    I'm guilty of (trying) to post comments in them too.
    In the past, many a FOR SALE thread has devolved/exploded because of unwarranted comments.
    I took the Marauder out for a nice 45 minute drive last night...man is this car fun.
    I had totally forgotten about the 'LEO effect'... Kept laughing as car after speeding car would slam on their brakes once they saw me!
    and by the time I got home I was figuring out how to do a Coyote/10 speed auto swap!!
    SOMEONE HELP ME HERE!
    Buy my Marauder before I start modding it again.
  1. For Sale 2003 MARAUDER FOR SALE 228,000 MILES
    By LFERRARA in forum Marauders for Sale
    Last Post: 01-11-2018, 07:58 AM
  2. For Sale 2003 Marauder 65k miles - Reducing the price to $12,500 for a quick sale
    By blackthorn in forum Marauders for Sale
    Last Post: 02-02-2014, 05:22 PM
  3. For Sale 2003 MARAUDER FOR SALE, BLUE, 42K miles, $14K, in CT
    By mm.owner in forum Marauders for Sale
    Last Post: 01-05-2014, 08:39 PM
  4. For Sale 2003 Marauder for sale- under 17,000 miles
    By mercwest in forum Marauders for Sale
    Last Post: 12-24-2013, 12:24 AM
  5. 2003 Marauder with 400 miles for sale -
    Last Post: 05-17-2005, 01:40 PM
