Results 1 to 15 of 17
Thread: alternator
    Oct 2007
    minnesota
    alternator
    Last night the lights went dim and the Amps gauge dropped low when I decided to pass a slower vehicle.
    2 things I see here.... either the serpentine belt is enlarging and losing traction on the wheel, or the engine spark demands more than the stock alternator is capable of. Sooo who has a good 200 amp alternator?
    Also... any point in upgrading plugs and wires? if so to what brand?
    The alternator is programmed to shut off at WOT, there is nothing wrong!
    Also, there are 10 second Marauders running stock coils.
    NGK plugs or Denso's work well if you have a blower.
    Dec 2004
    plymouth, mn
    Or it could be your alternator is crapping out. I had to replace mine. It started cutting in and out.
    Be prepared, these bad boys list for $370 ish.
    jeremy
    I always see a 200amp alternator for sale on eBay all the time. $240 plus shipping I believe.
    How many miles are on your car?
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Oct 2007
    minnesota
    captain says..
    40,000 miles
    programmed to shut off??! WHaaat?
    No electricity when you need it the most?
    none of my other Mercs or Fords did such a thing.
    I think its breaking down.
    Misquamicut, RI
    Quote Originally Posted by captain View Post
    40,000 miles
    If you do decide to go with a new alternator let me know. I will buy yours as I don't believe you can get the free-wheeling ones anymore. Myself, I think it's one of the coolest things about the car. Kinda sinister when you go WOT, all the noise and the lights dim.
    300A
    born 08-27-02
    Adjusted air in and air out.
    400+ timeslips.
    What Zack said is correct. The PCM controls the alternator and it is programmed to shut down at WOT. You don't actually "need it most" at WOT as you're only there for a few seconds and if the battery is in good condition it will carry the load for way longer.
    Oct 2004
    I thought the alternator was turned off as part of an aftermarket tune by SCT Exal2 many of use purchased from a vendor. I don't like it when the headlights go dim at full acceleration since most all my full throttle blasts are late at night.
    Misquamicut, RI
    I was under the impression that this was an early build feature only. Still, one of my favs.
    300A
    born 08-27-02
    400+ timeslips.
    Oct 2007
    minnesota
    the fix?
    is there a fix to this ? I dont like it at all.
    Its dangerous.
    And not very flattering, I would laugh at someone like me. Makes it look like your car is crapping out.
    What could the thinking behind this be??
    too many rrrrsss for the unit to endure?
    Saving herself for the horses?
    At 80 or 90 miles per hour I want more visibility not less.
    Hey... how bout the high beams come on automatically @WOT???
    Better, yes?
    Oct 2004
    Captain, I will second the motion for a fix on dim headlights under hard accelleration. At 80mph plus I wish I had the lumen power of a comercial air liner. My silver star ultra bulbs are great only when under full power. I thought a read a post on replaceing the lead wire to the bulbs. They said it improved the out put. Some one might pull the post.
    Oct 2004
    Southern California
    Its dangerous.
    If it's THAT noticeable, perhaps it's time for a new battery?
    BTW, lots of cars cut the alternator at WOT...
    Cheers,
    Jeff Cook
    '03 Marauder 300B, Dark Blue Pearl, Dark Charcoal/Flint interior, Badgeless front and rear, 4.10s and Lidio Tune
    Hawaiian Islands
    I go WOT all the time, in the dark, never noticed the lights going dim...
    ALOHA
    '03 A Build Date 8/02
    F.I.T. #6 ***RESURRECTED***
    *444 RWHP / 401 RWTQ
    *10 lbs. Boost
    *P1SC1 ProCharger
    Quote Originally Posted by Local Boy View Post
    ALOHA
    i second that. not enough for me to notice
  1. Alternator Repair!
    By 04MEMA in forum Shop Talk
    Last Post: 06-11-2007, 05:20 PM
  2. Alternator Clutch Issues
    By DeadVic in forum Shop Talk
    Last Post: 06-01-2007, 08:25 PM
  3. CVPI 200 AMP Alternator Swap
    By DeputyCSChavez in forum Shop Talk
    Last Post: 08-21-2005, 10:57 AM
  4. Help!! Alternator Part #
    By MMSuperFan in forum Community Discussion
    Last Post: 05-17-2005, 11:02 PM
  5. Alternator Pulley????
    Last Post: 01-11-2005, 10:49 PM
