MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > Marketplace > Marauder-specific Parts for Sale
Marauder-specific Parts for Sale This forum is for parts that are specific to the Marauder ONLY.
Reply
Thread Tools Display Modes
  #1
Old 04-24-2018, 07:22 PM
the fat bastid's Avatar
the fat bastid the fat bastid is offline
Kneel before Zod!
Trader: (6)
TFB's parts emporium: interior and trunk bits
Everything pulled from a black, dark charcoal 2004 MM (short ohc, no sunroof) with 250,000 on it. Be sure to send a PM for pics of what you are interested in so you know what to expect in terms of wear and making sure we are both talking about the right thing! Prices are obo but do not include shipping, Pickup in north NJ. Bigger parts tend to be extremely expensive to ship. Void where prohibited. All rights reserved.
I will typically respond by PM so be sure to check those, notifications on, box not full, etc
THE "I WANT THIS OUT OF MY HOUSE" SPECIAL
headliner - $50 (can not ship, no sunroof cutout, short ohc cutout)
From the engine bay:
1 fog light wire harness - $20
horn - $15
both hood hinges w/ shocks - $50
Little tiny bracket that connects the firewall to the driver's side fender lining - $5
Cruise control vacuum reservoir box - $10
Driver's side fender lining - $30
cruise control module w/ cable and bracket- $50
passenger side fender lining - $20
little bar that connects the passenger fender to the front bumper - $5
left and right bars that connect the fenders to the firewall - $10
hood latch - $15
left and right fender foam - $10
battery(maxx everstart maxx-65n) - $50
battery tray - $30
battery hold down plastic square (the metal pole is MIA) - $2
grill that goes over hvac hole that is under the wiper cowl - $10
blower motor w/ fan - $20
plenum bottom connector to hvac ducting-$10
upper radiator support -$40
lower radiator support -$40
bracket that holds the ac lines to the condenser - $5
upper and lower a/c line (from condenser to the, uh, evaporator?) - $50
radiator fan assembly - $50
coolant reservoir - $25
pcv valve - new -bwd (just the valve, not the elbow) -$10
engine w/ accessories from the throttle body on down and has cot - $900 (this should be at a price worth a rebuild). purrs like a kitten, eat a little oil.
power steering hose - about half of whatever the dorman replacement is
power steering reservoir - $20
a/c condenser - $75
radiator -
a/c evaporator (bottom has a spot of rust) -
trans cooler -
brake booster -
steering shaft -
just added fuel injector harness -
just added starter harness -
just added steering rack -
main engine harness- $200
From the interior:
3rd brake lamp - $20
all 3 oh **** handles - $20
A-pillar cover passenger side -$20
Rear lower bench seat (no cuts but has scratches) - $100
8 front seat screw covers - $25
center console pocket -$70 (has a small crack in the leather, 2 cracks in the plastic)
center console cup holder part - $60
glove box - $20
kick panels - $20
panel under the glove box - $20
4 speakers - $10 each
4 vents - $10 each
driver's door panel, has heat. doing the armrest lifting thing - $120
Passenger door panel, has heat. small chunk missing in dot matrix - $120
Kenwood execleon kdc-x789 + sir-ken1 sirius connect unit + pac swi-x streeing wheel radio control interface, antenna, pocket w/ aux input, sleeve, wiring harness, cables etc, manual, face plate cover - $100
upper and lower c-pillar covers- $20 each
rear door panel - $80 each
metal plate that is under the steering wheel - $5
both sail panels - $20
Gauge cluster w/ 255,904 on it. - $150
metal bracket for fuse box - $5
vertical metal bracket that goes from gauge pod to trans tunnel (not the gauge pod mounting bracket) - $5
carpet cover for the above - $10
metal cross bracket that goes under the steering wheel - $5
package shelf - $50
Viper 4806v + idatalink ads-al-ca + 2 remotes - $100
child seat upper and lower bolts and hooks - $10
rear antenna radio isolator - $20
rear upper bench - $100
headliner - $300 (still in car at the moment)
center console (missing 1 grill bar, another about to fall off) - $50
dot matrix gear shift surround - $75
vacuum harness that goes from the eatc to the hoses and stuff behind it. - $10
4 door panel switch covers w/ switches - $30 (the front panels are in poor shape, driver's side missing the tab. rears are ok. mostly buying the switches)
headlight switch - $25
2 cable covers that run down the length of each side - $10 each
door module - $30
aftermarket carpet that is darker than stock and doesn't have a mat hook + the rear rubber mat thing that goes on the back of the rear seat- $20
hvac duct/shifter mount w/ the forward AND rear plastic connector parts - $100
little plastic shield that goes above lcm - $5
metal bracket that holds in the lcm - $5
2 rubber inserts that go into the b-pillars - $10
metal bracket that holds the metal gauge pod bracket to the dash - $5
dashboard w/ the two little vents - $250
Heater blend door actuator module - $30
the lower plastic tube that connects the plenum to the plastic tube of the center tunnel. - $20
turn signal switch - $25
pats/defroster grill - $100
gas pedal assembly -
ecu -
passenger seat (small hole by the lower track) -
steering column cowl/cover/shroud/whatever-
2 keys and ignition lock (should this go with the ecu?) -
padding in front of the dashboard -
the metal skeleton under the dashboard -
shifter - $75
steering column -
hood popper handle and cable -
hvac box, ducts, etc -
e-brake pedal and popper assembly -
the thicker interior carpet stuff on the firewall -
driver's seat (it is currently in pieces. I removed a piece of carpet the previous owner put under the foam as it is missing the white netting.)
just added Door rubber strips -
From the trunk:
mini-spare tie down - $15
trunk latch trim piece - $20
cd changer w/metal wing mounting brackets - $20 (no magazine, does not latch the magazine)
cd changer carpet cover thing - $20
trunk carpet - $30
trunk upper carpet - $20
air ride off switch - $15
fuel pump off button - $10
just added trunk rubber strip -
just added latch striker -
Exterior:
rear bumper cover (has a sag and funny wave in the side) - $350
2 rocker covers - $189,457.88
little triangle things at the bottom corners of the windshield - $5
2 wiper arms w/ wiper blades of indeterminate quality - $20
wiper motor w/ arm assembly - $50
wiper cowl rubber -
wiper cowl squiter line -
just added Fuel door (black with thumb tab) -
just added gas cap
just added passenger side doors (little bit of rust on the inside of the bottoms)
6 lug nuts -
Under carriage:
driveshaft- $50
front sway bar -
H-pipe -
driver's side catalytic converters -
passenger side catalytic converts -
o2 sensors -
just added watt's link -
just added gas tank -
just added fuel evap thing
just added watt's link stud
Pending:
Sold:
Upper b-pillar covers- $35
ashtray - $26
washer fluid bottle w/ pump - $20
rear view mirror - $15
thermosat, housing, and hoses-$45
Rear air suspension module - $80
suncore air compressor - $50
interior wiring harness - $200
fuel pump hat assembly - $10(wiring damaged)
Fuel Pump Driver Module - $25
Blower control module - $40
rear sway bar - $100
rear center seatbelt connector - $5
front bumper -$50 (not the cover, this is the actual bumper. a few of the plastic things are missing)
main airbag module - $65
3 air bag senors - $50 each
2 Lower b pillar covers - $20 each
Passenger air bag - $40
driver's air bag - $75
Driver side mirror - $75
passenger side mirror - $25 (the paint has peeled off the skull cap almost completely)
5 seat belt assemblies (with related hardware) - $40 each
Subwoofer in box (no amp) - $50
floor mats - $50 (the drivers side has a hole in it)
steering wheel - $65
panel under the steering wheel - $20
2 key fobs (virtually unused and new) (should this go with the door module?)- $30
air box assembly with MAF and air filter- $150
1 SilverStar Headlight Bulb Sylvania 9007 hb5 st - $5
Door knob pulls - $15
passenger door molding (all 3 pieces) - $40
Center gray dash trim around vents and cluster (has a little light added to it) - $35
light control module - $100
tyc tail lamps (left and right sides), NEW - $150
ford factory remote start system - $30
mini-spare - $95
ohc - $50
driver's floor mat hook and clip - $10
keypad - $25
hood - $90
gauge pod metal mounting bracket - $10
the metal piece that holds in the sub box + bolts - $15
driver's fender - $100
All 4 sill pieces - $40
beauty cover that goes over the throttle linkage (engine bay) - $20
radiator beauty shield thing - $100
jack, pouch, full size tie down, instructions (generic) - $100
Long trim - $100
2 corner lamp wiring harnesses - $40
Front license plate bracket - $90
Both visors - $40
eatc - $50
TYC driver's side corner turn lamp - $20
cargo net - $15
2 arnott air bags and 2 o-ring kits, NEW - $200
destroyed in crash / trash / unavailable:
wiper cowl
grill
headlights
passenger fender
passenger turn signal
header panel
front bumper cover
fog lights
spare tire cover
metal cooling tube that parallels the engine
brake line from rear and forward mater cylinder port to abs valve body
Trunk lid + spoiler
abs module + valve body
master cylinder
short trim piece
__________________
garage
  #2
Old 04-24-2018, 10:33 PM
03MERCMARAUDER's Avatar
03MERCMARAUDER 03MERCMARAUDER is offline
If your Gonna boost it, Boost it hard
Trader: (1)
I will take the cargo net
__________________
2004 SB
4.10's and a tune
More to come
  #3
Old 04-25-2018, 10:51 AM
gdmjoe's Avatar
gdmjoe gdmjoe is offline
Member
Trader: (12)
Post
You've Got PM!
  #4
Old 04-30-2018, 02:00 PM
Kneel before Zod!
Trader: (6)
More parts in stock! First post updated!
__________________
garage
  #5
Old 04-30-2018, 05:18 PM
2mercs's Avatar
2mercs 2mercs is online now
Senior Member
Trader: (1)
Pm sent.
Sent from my SM-G930V using Tapatalk
  #6
Old 05-02-2018, 04:20 PM
Kneel before Zod!
Trader: (6)
now with more parts!
__________________
garage
  #7
Old 05-06-2018, 04:47 PM
Kneel before Zod!
Trader: (6)
__________________
garage
  #8
Old 05-06-2018, 05:14 PM
Trader: (1)
What shape is the trunk carpet in?
Sent from my SM-G955U using Tapatalk
__________________
2004 SB
4.10's and a tune
More to come
  #9
Old 05-07-2018, 04:14 PM
Kneel before Zod!
Trader: (6)
more parts in!
__________________
garage
  #10
Old 05-07-2018, 04:44 PM
03Merc's Avatar
03Merc 03Merc is online now
Senior Member
Trader: (10)
Pm Sent.
  #11
Old 05-08-2018, 02:53 PM
Kneel before Zod!
Trader: (6)
more parts added!
Also, price adjustments on stuff!
__________________
garage
  #12
Old 05-09-2018, 05:42 PM
Kneel before Zod!
Trader: (6)
it never ends! more!
__________________
garage
  #13
Old 05-10-2018, 10:20 AM
Mr. Man's Avatar
Mr. Man Mr. Man is offline
GAME OVER, YOU LOSE!
Trader: (2)
What color car are you pulling parts from?
  #14
Old 05-10-2018, 10:22 AM
Kneel before Zod!
Trader: (6)
Good question! I'll update the first post. Black with dark charcoal interior
__________________
garage
  #15
Old 05-11-2018, 04:17 PM
Kneel before Zod!
Trader: (6)
More crap in stock!
__________________
garage
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For Sale Various interior parts DTR2007LX Marauder-specific Parts for Sale 0 02-16-2016 01:31 PM
LED's for Interior/Trunk-Hood-Tail Light NATEHAWK Community Discussion 15 04-18-2011 06:09 PM
Wanted To Buy wtb interior parts scotty230 Marauder Parts/Misc. Wanted 4 04-19-2010 05:21 AM
MM Interior parts F/S Herco23 Marauder-specific Parts for Sale 18 02-05-2009 05:38 PM
Powered by: vBulletin
