MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 10-09-2017, 12:32 PM
Chayton's Avatar
Chayton Chayton is offline
Senior Member
Trader: (0)
Question Name that rattle? (VIDEO)
On today’s episode of “name that rattle!” We have a 2003 Mercury Marauder. The owner is experiencing a rattling sound at idle, coming from directly under the car. The owner believes it sounds like the drivers side primary cat on its way out, but he wants to hear from the experts!!! Feel free to chime in!
https://youtu.be/KaGhEAcBaQA
Note that in the video, when the sound goes away is when I give it baby gas. Let off and it rattles.
__________________
98 P71 SOLD
2003 MARAUDER ~ Race Car
2002 Crown Vic Sport ~ DD
  #2
Old 10-09-2017, 01:36 PM
Chayton's Avatar
Senior Member
Trader: (0)
bump? come on this is supposed be fun!!
__________________
98 P71 SOLD
  #3
Old 10-09-2017, 01:53 PM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
tap on the cat and see if it rattles, sort of sounds like cat..what does it sound like under hood? doe the sound come from cat area?
__________________
  #4
Old 10-09-2017, 01:59 PM
Chayton's Avatar
Senior Member
Trader: (0)
Quote:
Hard to hear from under the hood, its definitely coming from the bottom. I was thinking CAT or maybe the $300 torque converter I have in there? Will do more investigating once I get home.
__________________
98 P71 SOLD
  #5
Old 10-09-2017, 03:00 PM
ab9sgken's Avatar
ab9sgken ab9sgken is offline
Member
Trader: (0)
Quote:
Hear shield of cat I think.
Sent from my SM-G920P using Tapatalk
__________________
2003 Model 300A
VIN: 2MEHM75V93X611525
Assembled on 06/05/2002
#699 of a build of 7838 and
#699 of 7093 in black
50,000 miles on it
2002 Grand Marquis LS
149,000 miles on it
Arizona Beige Clearcoat Metallic
2009 Grand Marquis LS Limited Edition
53,000 miles on it
Silver Birch Clearcoat Metallic
  #6
Old 10-09-2017, 03:07 PM
ab9sgken's Avatar
Member
Trader: (0)
Heat shield of cat I meant to say.
__________________
2003 Model 300A
50,000 miles on it
149,000 miles on it
53,000 miles on it
  #7
Old 10-09-2017, 04:10 PM
2mercs's Avatar
2mercs 2mercs is offline
Senior Member
Trader: (1)
Didn't someone have a cracked flex plate making a similar noise?
Sent from my SM-G930V using Tapatalk
  #8
Old 10-09-2017, 05:16 PM
JimP's Avatar
JimP JimP is offline
Senior Member
Trader: (0)
Check the Torque converter bolts to the flywheel.
__________________
1987 GN running 10's. 2003 MM Blue Sold and dearly missed!
2003 Black 300B
Procharger P1sc with air to air intercooler
3,000 PI converter
4.10 Eaton posi 31 spline carrier
Moser 31 spline axles
Koos headers, with custom stainless exhaust, Megs tips
Carbon fiber drive shaft
Metco control arms
Every autometer procomp gauge in the catalogue
  #9
Old 10-09-2017, 05:32 PM
1Marauder's Avatar
Senior Member
Trader: (5)
Yes, sounds like two pieces hitting each other... heat shield or mount pieces clanking agaist each other.
When I've heard inside cat baffles come loose I've heard more like BB's a looser higher sound... although I guess it could be one bigger piece comming loose and clanging against inside.
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Car fixer alignment.
  #10
Old 10-09-2017, 07:12 PM
Chayton's Avatar
Senior Member
Trader: (0)
UPDATE: I gave the cat one good smack with a BFH. Noise gone for now
__________________
98 P71 SOLD
  #11
Old 10-09-2017, 09:27 PM
Chayton's Avatar
Senior Member
Trader: (0)
I lied. Noise seems worse now. ****. praying this isnt rod knock... if it was, wouldnt it get louder with revs? even the tiniest bit of throttle and it goes away. Didnt have a chance to tighten the torque converter bolts since I need a helper. Praying its not the dreaded rod knock... ugh
__________________
98 P71 SOLD
  #12
Old 10-10-2017, 08:04 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (39)
Flexplate .....
  #13
Old 10-11-2017, 07:01 PM
drwhy drwhy is offline
Junior Member
Trader: (9)
Sounds similar to the cat converter problem that was present on a lot of 04 Crown Vics. I had one replaced on the 8 year, 80,000 mile warranty, way back when.
__________________
2003 Marauder 300B, Blue
Trilogy 0003
Lidio Tune
MMX / 4.10s by Kenny Brown
Trilogy 0013
Dual position chip
California CARB test car
2003 F-250, Gray
2003 Excursion, White
1996 Corvette RPO Z-16, Blue/White, Red Leather
1996 Corvette, Red, Red Leather
  #14
Old 10-12-2017, 09:10 AM
1Marauder's Avatar
Senior Member
Trader: (5)
Chayton... What ways it? You can't leave us hanging!
__________________
  #15
Old 10-16-2017, 08:46 AM
Chayton's Avatar
Senior Member
Trader: (0)
Quote:
I think its flexplate... Been dealing with some crap so havent had the motivation to get under there. Hopefully this week..... :/
__________________
98 P71 SOLD
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Got a rattle cougar9150 Shop Talk 8 05-03-2011 05:02 PM
Rattle at low rpm. bigdhasmoney Shop Talk 13 01-15-2011 10:23 AM
Suspension (?) Rattle ledzilla Suspension & Brakes 16 12-03-2009 11:58 AM
Rattle in B pillar mdskiing Shop Talk 1 12-22-2006 08:21 AM
Speaker Rattle valkyrie Community Discussion 1 06-16-2004 11:07 PM
Powered by: vBulletin
