Page 1 of 3 123 LastLast
Results 1 to 15 of 43
Thread: suddenly running like CRAP and running is an overstatement.... Cam sensor?
    Oct 2015
    SF bay area, CA
    2003 Marauder, 165k mi
    I bought it from the original owner, with 100k on the clock, dealership maintained with papers.
    Ive been great with maintenance too.
    Trans rebuilt with jmod and spring removal ~150k
    New plugs and MSD coils ~160k
    It was running fine, been running errands the whole day. As I was coming up on my exit it tossed out a CEL and started shaking...
    As I came to a stop it stalled, I was able to start it and limp it home.... running like **** it felt much like it was running on 4, but not as smooth. it coughed and shook a LOT
    I got the codes a P0340 and pending P1336
    Ordered a new cam sensor... No change with the new sensor installed.
    Anything else to look for?
    I heard there can be chaffing problems, but everything I've seen looks fine. all the connectors appear good.
    May 2009
    Moreau Island
    Crank position sensors are more prone to fail on these than a cam sensor. I’d start there. Worst case you’ve jumped time.
    Oct 2003
    Beaufort, SC
    Blown out plug??
    Probably blew a vacuum line off.
    Blog Entries
    2
    This happened to mine recently. Amazing how poorly it runs.
    Will it idle?
    Broken cam gear? It’ll make it run on 4 cylinders for sure.
    Trilogy # 192 / T.S. 0012
    Nov 2012
    Sacramento
    Yup, or CAI is loose at a joint.
    Oct 2015
    SF bay area, CA
    helpful, thanks!
    I know my cam chains have a bit of rattle at startup, but it seems unlikley to jump time as im cruising on the freeway (like during the moment it started)
    -If it were to jumps I'd expect it to happen during startup after sitting or while doing something stupid. burnouts racing ETC
    Im a gearhead with way too many vehicles...
    Im here to talk about my 03 Marauder. 300A/B (I have a weird mix)
    165k miles as of dec 2018
    Jmod, removed 2 springs
    flomaster
    tint and 2din headunit + bigger sub
    Oct 2015
    SF bay area, CA
    Blown out plug??
    confirmed no
    flomaster
    Oct 2015
    SF bay area, CA
    funny, recently it was acting like it had a bad cat... upon inspection I found the driver side valve cover to intake breather to be loose... got a new elbow and checked the other lines.
    The passenger to intake breather is about time for replacement, but wouldn't do this.
    I dont think broken, despite the coughing and missing it sounds like its rotating OK.... if it has anything to do with timing Id say it hopped a tooth, but it doesnt sound like that happened.
    checked the whole intake bath, everything is tight.
    Will it idle?
    it will not idle on its own, I can give it a little gas to help iot stay running, but it really doesn't want to.
    flomaster
    Nov 2012
    Sacramento
    sophomoric... Grounds, power cables?
    Oct 2015
    SF bay area, CA
    everything seems fine.
    never had power issues
    flomaster
    Oct 2003
    Beaufort, SC
    Quote Originally Posted by Starshooter10 View Post
    confirmed no
    GOOD!!
    Oct 2003
    Beaufort, SC
    IAC Valve maybe??
  1. Anyone running 265 50 18's?
    By sflrainmaker01 in forum Tires & Wheels
    Last Post: 12-03-2013, 03:26 PM
  2. Car running hot
    By mgmsleeper in forum Shop Talk
    Last Post: 04-18-2012, 09:27 PM
  3. How much PSI are you running?
    By bawazir in forum Power Adders
    Last Post: 02-21-2010, 07:43 AM
  4. Car running hot
    By Mike827 in forum Shop Talk
    Last Post: 01-19-2010, 04:26 AM
