Results 1 to 15 of 15
Thread: Help
    Help
    My differential case has tooth missing. Should I just replace it with another the same or should I upgrade? If I upgrade which do I choose to fit my original axles? I found out cause we are installing 4:10 gears
    Sent from my LG-H918 using Tapatalk
    03 or 04 Marauder, crown Vic or grand Marquis has same rear axle housing. Gear ratio most likely different. Mid year 05 and later are 31 spline axles. Yours are 28 spline
    Jun 2008
    Waukesha, WI
    If it was me, I'd try to find a used side or spider gear and replace the broken one.
    Would gear ratio make a difference?
    Sep 2005
    Buffalo, NY
    Get a Detroit trutrac and forgetaboutit.
    Built: 3/16/2004
    Must - Go - Faster !
    Quote Originally Posted by chivio2000 View Post
    yes it will, you have 3.55. Some police cars had 3.55, but a lot had 3.27..civilian cars are 2.73 unless a sport or hpp model..The shifting will all be wrong, etc...
    gear ratio can be changed, but if you find a 3.55 one, then swap whole thing
    Dec 2014
    Hastings, mi
    He has my old tuner that is setup for 3.55 or 4.10 tuning.
    #BSTDMRC #LSSWAPPEDMARAUDER
    Instagram -
    Cheapthrillb2
    lsswappedmarauder
    03 Marauder Spider Gears
    Was going to install 4.10 gears. Spider Gears all chewed up. Are there any replacement if yes part #? If no what internals can I install to replace? I saw some trans lock but which can I install with no modification and continue using my splines and rear end cover. Or any ford 8.8 28 spline fits?
    Jun 2012
    Grand Rapids
    There are no replacement parts available for the Marauder posi unit other than clutches. You are going to have to purchase a new carrier... I would buy an Eaton Tru-Trac
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Quote Originally Posted by Curless View Post
    If I'm on a short budget what other recommendation?
    Instead of the Eaton Tru-Trac what other you recommend ?
    Jun 2012
    Grand Rapids
    #2941 300A
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Christmas in a cup
    Cocka Two
    Use car-part.com to search for an axle with 3.55 gears or part it out
    Washington State
