Results 1 to 15 of 24
Thread: Meziere Electric Water Pump Installed
    For sure a great idea! Picked up 12 hp and 8 ft-lb tq at the peaks, but the real story is at lower rpms. At 3500 rpm, picked up approximately 20 hp and 35 ft-lb tq. I'm anxious to get a dyno test/tune with the t/c locked to see what it does at the very low end, like 1500 or so. That's coming soon, when I change the MAF sensor.
    I got the anodized pulley, and the wiring is pretty much hidden, so you don't really notice that it's not stock unless you look closely.
    Since I have the underdrive crank pulley, it required a shorter belt, Gates part # 60905. With stock pulleys the OEM belt works ok.
    Tested it in rush hour traffic, ATL I-285 northside at 3:30. Gridlock and 94 degrees. No cooling issues hatsoever. Talked to many more electric water pump users since making the decision and got nothing but good reviews. I agree!
    Will post pictures later.
    edit: try here for a pic:
    http://www.mercurygallery.net/mmnet/...php/photo/3539
    edit: forgot to say, 297 RWHP now!
    I was fortunate enough to see my buddy Brian...AND his Dyno sheets this afternoon.
    Come on UPS, Come on UPS....
    Florida
    The one thing I do not like about this site is that I can't keep money in my pocket. Here we go again. Next a water pump.
    Empty Garage, but Fat bank account
    Quote Originally Posted by tmac1337
    I hear that. And for financially challenged people, like me, it makes keeping focus on your primary upgrade objectives tough. In the mean time I live vicariously through everybody else's Marauders.
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Motor City
    Does this pump have an idler pulley? There was one manufacturer of a electric pump (Meziere I think) which had some quality issues with the pulley breaking off. That was a little while ago and they may have it fixed by now. But, I just wanted you give you a heads up to keep an eye on it for a little while. This makes me want to get one too!
    Chicago
    So with all this talk about limits to the S/Ced engines at around 450 hp, if this adds 10 - 20 hp above that does this not count since it is really adding hp by taking away the work load of the ingine to run the mechanical pump. Or does hp still exhert the same forces on the engine wether it is an addition or by the reduction of its lossage.
    Steven
    2004 Marauder Black, loaded
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    476.9 rwhp 385 lbs/tq
    Lidio tune
    2004 Suburban Dark Charcoal
    Quote Originally Posted by stevengerard
    2 of the strongest supercharged MarkVIIIs on the planet are using these pumps. That ought to say something about whether it's worthwhile.
    Chicago
    I'm not questioning wether its worthwhile, I am asking a physics question I don't know the answer to. The S/C adds hp by addition, an electric fan, water pump and fule pump, lighter pistons, cooler air intake, add horse power by reducing the work load of the engine itself. so does all this additional hp still add up to a dangerous amount. Lets say you are at the 450 hp of our engines and add an additional 55hp with all of these items is it now dangerous beacuse you are at 505 or is it really ok since you only pushed the power with additive hp to 450. Just a question of what hp and load means not a question of value.
    Steven
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    Lidio tune
    May 2003
    Edmonton, Alberta
    No, you aren't forcing the engine to make more horsepower. All that is going on with the waterpump thingie is you are letting more of the horses that were already there go to the rear wheels.
    There's no danger of blowing it, all this does is make the engine have to do less 'extra' work. The horses were already there.
    If you were to pull off the A/C pump, and power steering pump etc, you'd also see increases in HP. You'd be hot and have to drive in a straight line, but you'd free up more ponies
    2003 Marauder 300eh - Stock
    Born: 12/03/2002
    Adopted 02/17/2003
    Trilogy #243
    AVIC D3
    SS Inserts.
    Metco Control arms and Watts link.
    QA1 8 way adjustable shocks and struts.
    Addco front and rear anti-roll bars.
    Wilwood front brakes.
    I can't drive 55. I'm looking forward to not being able to drive 75 ether.
    Houston, Republic of Texas
    Quote Originally Posted by Dr Caleb
    Sounds like a car for the drag strip!
    2003 MM 300A
    Born June 18, 2002
    Adopted Christmas Eve, 2002
    First Factory Rebuilt Ford P.O.S. Engine at 81,000 miles
    Second Factory Rebuilt Ford P.O.S. Engine at 101,000 miles
    Ford Racing 4.10's
    Reinhart/XCal2 Custom Tune
    Reinhart Underdrive Pulleys
    K&N Conical Air Filter
    Reinhart Exhaust with 18" Magnaflows
    Silencer Removed
    Bosch Micro Edge Excel Wiper Blades
    Bob White Red Bumper Inserts
    Lone Star Beer in cup holder
    Fellowship of Christian Cowboys
    license plate bracket
    God and the soldier we adore, In times of danger, not before.
    The danger gone, the trouble righted, God's forgotten, the soldier slighted.
    Cynicism is the smoke rising from the ashes of burned out dreams.
    I am sold on it, so if we can get this thing going I will setup a group buy, I re'did Kieths car today on the dyno it made 458 RWHP on 9 PSI I am afraid to think what it will do with a electric pump LOL
    http://web.iwebcenters.com/reinharta...3758-kieth.jpg
    Chicago
    [QUOTE=Dennis Reinhart]I am sold on it, so if we can get this thing going I will setup a group buyQUOTE]
    I'm in as long as I'm spending
    Steven
    Vortec S/C
    4.10s
    3500 PI Stall
    Kook's headers
    Lidio tune
    Everett, WA
    I'm in for the group buy. I will also need the other parts since I have the UD pulleys now.
    2003 300A Black Mercury Marauder 4334 of 7839
    Trilogy #150 installed by Carfixer & Tallboy 4/21/2007
    (brute's garage)
    Do you know what the part # for a gatorback would be. I have steeda underdrives as well. Also was it hard at all to wire in, I have a 98 towncar I guess there is an extra switched 12 volt empty fuse on 03+marauders but wasn't sure how to wire it on mine.
    Quote Originally Posted by purelux
    Sorry, I don't have the cross reference info, just the number that is on the belt. I had it installed and wired at Team Ford. I don't believe the wiring job is difficult, but wrapping the wiring and tying it in with the rest of the harness so it looks OEM may be a bit more involved.
  1. Why the cooling mod is important
  2. Meziere electricwater pumps
    Last Post: 06-27-2004, 12:47 AM
  3. I'm on my third water pump!
    By Fourth Horseman in forum Shop Talk
    Last Post: 06-08-2004, 08:17 AM
  4. Doh! New water pump at 10,400 miles
    Last Post: 03-18-2004, 09:36 PM
