When you get underdrive pulleys on a Marauder do you still use the stock belt?
Yes, the stock belt still fits and works perfectly. I use a gatorback-type belt in the stock size with my u/ds.
Yes.
But there are issues with the U/D pulleys on these cars. Specifically with the stock altenator pulley.
EDIT: Disregard if you do not have the clutch'd alt. pulley.
11.98 @ 115 mph"Comfort, Class and Hair on Fire Performance."
I had underdrive pulleys on my car for almost 2 years with no problems at all. The only minor issue was that the lights dimmed a little at idle when there was a heavy draw, but Dennis bumped the idle in Drive speed by 100 RPM and that cured it.
The 2001 Cobra (4V) used the same u/d crank pulley as the 2V Vics/GTs.
There has been quite a few problems regarding front crank harmonics/vibration due to the smaller diameter crank pulley.
Wasnt this due to improper installation??Originally Posted by metroplex
2003 MERCURY MARAUDER 300A
Build Date
5/31/02
Sequence#
#363 of 7839 Black Marauders
Dyno tested power
Best 1/4 mile time to date
12.456@109mph
Visit my Garage
Blackened300a's Garage
Originally Posted by Blackened300a
Yes I believe it was.
2003 Marauder 300B,
Heated Seats
35% Tint
Mercury All Weather Mats
1973 Oldsmobile Toronado
2012 Kia Sedona Van
2008 Corvette Convertible
2021 Prius Prime Limited
Member # 440
----- John
