Hey Guys,
I need to know all the specs on the 1994-2002 Crown Vic/Marquis rims and the 2003+ Crown Vic/Marquis rims.
I need the following
Wheel Backspacing:
Wheel Offset:
Wheel Size:
Thanks
Bowman9
Hey Guys,
Wheel Backspacing:
Wheel Offset:
Wheel Size:
Thanks
Bowman9
Later,
Bowman9
Modifactions:
SuperChips Custom Tuner 9100 (Lidio)
180 Degree Thermostat
Ford Motorsport 4.10 Gears
Steeda Underdrive Pulleys
K&N Coldair Kit
OEM Marauder wheel;
Wheel Backspacing: 6.295"
Wheel Offset: 50mm
Wheel Size: 18X8
Bolt circle: 5 lug, 4.5" pattern
Uses 1/2 acorn style lug nuts.
Oops...Just noticed this is not what you asked. Sorry, but I'll leave it in case it helps someone else?
Thanks this info does help me,
I am also looking for info on the pre 03 wheels.
Originally Posted by SergntMac
Later,
Bowman9
Modifactions:
K&N Coldair Kit
Did you ever do anything with that grill I sent you?
No not yet, me and my friend have been stratching our heads over how to give a more depth to the opening like a Crown Vic PI grille.
Originally Posted by Zack
Later,
Bowman9
Modifactions:
K&N Coldair Kit
Nobody knows the specs of the pre 03 wheels?
Here's the story, I have been working for an online mustang wheel and tire reseller as a customer service rep for a little over a month now and we get calls every now and then about wheel fitment for the Crown Vic/Marquis for both the pre and post 2003 models. But seeing most of the people working there are mustang guys they don't want to bother with these customers.
I would like to help these customers get aftermarket rims, but I don't have specs of the wheels.
I am working on getting a damaged 2005 mustang rim from stock to test fit it on my 2003 marauder.
But I do not have any info on the pre 03 Vics/Marquis' wheels.
I would rather not say what company I work for at this time, because it might "break" the forums vendor rules.
I have shot of a few PM's to moderators to find out what is needed, because if we find the correct fitting wheels we would like to offer MM.net a forum discount.
Later,
Bowman9
Modifactions:
K&N Coldair Kit
