Originally Posted by
SC Cheesehead
How many miles on your car?
Sounds like a low mileage Marauder, but...
Buyers will need to know the mileage to judge what a fair value is for your Marauder.
Mr. Man
It doesn't have a Cobra engine unless you replaced the OEM and
4.6liters is a small V-8 a measly 281 cu in, but I wish you all the best in finding it a new home.
Maybe he's talking about the 4.6 DOHC's exterior dimensions....especially the cam covers!
Good luck with the sale!
