hi brothers ..
I have decided to use Lower Degree than the stock .. coz the Temperature is High over here !
So what do you think guys about 160 Degree??
Thanks
hi brothers ..
Thanks
2004 DTR MM1454 of 3213 in 04'471 of 983 DTR's1 of (??) in saudi arabiaone of 1213 with the moonroof option
I have the corect part number for it somewhere and I will look forit.
My tuner - Sal @ PSP - cautioned that when going to the lower temp T-stat you really should adjust the radiator fan to run at a lower temp and most importantly adjust the closed loop/open loop function of the tune for the lower temperature so you don't get stuck in the "cold engine/warm-up" mode waiting for the engine to reach an operating temperature that it might not reach due to the lower temp. T-stat.
Plate - "EVILMERC"
Exactly, if the computer isn't setup for the lower temp you may do more harm than good. Fox body guys throw 160's in their car then wonder why they run like ass.
Also If your T-stat is 195 and your car is running 210+ you have another problem other than your T-stat.
Matt H.
(sold)2004' SB, 268rwhp/295tq
2017 F-150, 5.0
2013 SHO DIB Performance Pack
The best combustion occurs at about 190-195 degrees.
If it ain't broke don't fix it.
2011 Infiniti M37x
2000 BMW M5
1976 Jeep DJ5 (postal)
^^^what they said^^^
Replacing the thermostat alone will do nothing useful for you.
2003 MERCURY MARAUDER 300A
Build Date
5/31/02
Sequence#
#363 of 7839 Black Marauders
Dyno tested power
Best 1/4 mile time to date
12.456@109mph
Visit my Garage
Blackened300a's Garage
Couldn't you also look at it from the perspective that, running the engine cooler, REQUIRES more timing to achieve efficient combustion? Rather than assuming that adding timing is always a positive thing? Like a good cylinder head, will make max power, requiring less ignition timing advance, than a poor cylinder head that takes a lot of lead time to achieve complete combustion?
2011 Infiniti M37x
2000 BMW M5
Plate - "EVILMERC"
No problem Jake!
That motor is safe with that T-stat!
