Results 1 to 15 of 24
Thread: Is this a member's car?
    All the info says is 2003 with No Mufflers.....yeah I can hear that lol
    http://youtube.com/watch?v=d4w4JSMFB48
    By far the only ricey MM I have ever heard.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Dec 2006
    Southern Maryland
    I don't know, the Corsa mufflers I have heard sound terrible on the 4.6. They make it sound like a weak ass V6.
    2011 Infiniti M37x
    2000 BMW M5
    1976 Jeep DJ5 (postal)
    wow, that is depressing...
    96 GM HPP 206K mi.(chassis), Tuned by Manny at HPP, 76mm DBB PT, SQV BOV, Accufab TB/UP, Tial 44mm WG, 3" Intake and 3" Single Exhaust piping, PI Intake, PI Cams, MMR Stainless Valves, Manley Springs, P&P PI Heads, Forged Rods and Pistons, 90mm Lightening MAF and injectors (42lbs), 255 Walbro, BOC Trans, BOC Stage II TC 3,000 stall, 3.73, Trac-Loc, Cobra Carbon Clutches, AMMX driveshaft, SCT Xcal II J-Tune, Transmission cooler, PowerSlot Brakes, ENS front control arm bushings, Addco Front and Rear Swaybars, Poly Endlinks and Clamps, Front and Rear Bilstien Shocks, F/R PI springs, Rear ENS Control Arm Bushings, custom structural re-enforcement(stabilizer bar mounts and lower control arm mounts, among other spots), Custom Boxed Lower Rear Control Arms, Kenwood HU, Alpine Type R 5X7's, Kicker Comp 6X9's,Alpine 4X50, Crunch 1100 subwoofer Amp, Image Dynamics 12" subwoofer, Yellow Top
    i left him a comment lol
    Nothing like hitting the rev limiter in neutral.
    Deusch Bag
    Apr 2008
    HOME OF THE BRAVE!
    I doubt they're members...next year I'm pretty sure that same car will be sitting on 24 inch rims and featured in DONK magazine.
    "Damned if I do, damned if I don't!"
    Member #8831
    MERIDEATH aka "Purrrty Mean" was born on June 20, 2002.
    Production #1685 of 7,838 and is #1685 of 7093 Black Beasts.
    Delivered July 27th 2002, she revealed herself.
    Unable to be tamed by her 1st owner, she was left to roam about & raid in search of plunder.
    Through the pillage she became mine on January 23, 2008 and since then...
    "She's tryin' to make a Devil out of me!"
    -"TaKe 'Em D0wN!" TRILOGY TwinScrew #209 / TS0019-
    Apr 2008
    HOME OF THE BRAVE!
    yuck!
    Quote Originally Posted by takedown View Post
    Car also sounds like a 750 Honda Motorcycle!
    Member #8831
    Feb 2005
    Parkton, MD
    My Beetle sounds better than that!
    Probably wrecked before that grisly fate unfolds. Either way its future is bleak.
    Just another clown on a bike...
    As good as any man, better than none.
    Former owner of a highly modified and very fast Marauder.
    "You CAN fit a square peg into a round hole, all you need is a big enough hammer." -Original
    OMFG!!!
    That is THE MOST rednecked exhaust I've ever had the misfortune of hearing!
    Another moron who is out embarrassing ALL the other Marauder owners...
    BTW: I love the: "Is it smoking!??!"* comment at the end of the video....
    Well, If you quit revving the living ***** out of the engine with no load on it...it might not smoke!
    *sounds like Joe Frasier!!!
    Lehigh Valley, PA
    Their from maryland, from the looks of the plate.
    I have other things that i can say but i wont.
    2063/3214
    5377/7838
    Aug 2007
    Newport News, VA
    ^^^I was just going to say that the plates looked like Maryland ones
    Apr 2005
    East of Cleveland, Ohio
    Isn't there a member on here that recently removed his mufflers? I remember a thread not that long ago about it.
    But yeah, that sounded awful.
    Jun 2007
    Bonita Springs, Fl.
    Quote Originally Posted by Darkside View Post
    Yes, that was me. I am muflerless. BUT Mine sounds ALOT better than that one does. He has done other things to his car, because it is night and day.
    http://www.youtube.com/watch?v=qT95f-fDz9k
    2003 300A BLACK DD
    Sequence # 4569 of 7839
    Silver Inserts / K&N CAI / Drilled - Slotted Rotors
    DR Xcal2/Under drive pulleys (thank Rich)/180 T-stat
    EMP water pump / Denso irridiums (thanx Rich)
    Diamond Plate Radiator Cover and Air Dam, made by and broken in by magindat.
    Custom Embroidered SB Head Rests (Thanx Rich & Rex)
    Running with no mufflers, makes me sound fast!!
    Upgraded Sound System (John's Stereo)
    -Pioneer AVIC-D3 w/ XM & iPod
    -Pioneer Premier Speakers
    -MTX TC3001 Amp
    -MTX 10" Sub w/ Custom Box and LEDs (magindat)
    adopted 6/12/07 - 20,956 Miles
    SOLD 2/23/13 - 73,286
    Contemplating a battery handle delete
    Aug 2007
    Belleville
    the same a$$ hat has a few more videos on youtube with a crown vic with "straight pipes" and it too sounds like garbage. Why??
    Dec 2007
    AZ
    If it is a member on here please allow me to be the first to extend you the courtesy of asking you to leave.
    Number 664 of 3213, born on 10/17/03.
    www.MNRImages.com
  1. Exotic Car Time Share Club??
    By MM03MOK in forum The Lounge
    Last Post: 06-17-2006, 09:34 AM
  2. Used car best buys
    By dwasson in forum The Lounge
    Last Post: 06-05-2006, 07:49 AM
  3. S/Ced MM the best all around car?
    Last Post: 08-24-2005, 04:14 AM
