Results 1 to 15 of 15
Thread: OEM radio config question.
    Oct 2007
    Ruskin, Fl
    Hi,
    The radio in my 2003 Marauder stopped receiving. I found the exact radio out of a Crown Vic. Same model number except the new one ends in -AK instead of -AA. (2 years newer manufacture date too) Radio took minutes to swap. My question it how do I change the configuration?
    Config 2 and EQ do not come up when I hold the 3 and 6, than preset 6. Also no subwoofer anymore.
    Any help would be appreciated.
    Michael
    Quote Originally Posted by cw1115 View Post
    Hi,
    Michael
    If there is no subwoofer and you can't change the config, the radios are not the same.... just sayin.....
    I would have done the Escape radio swap. You'd get a better sounding radio, subwoofer, internal 6 CD changer, etc.
    Oct 2007
    Ruskin, Fl
    Fastblackmerc, the radio is the same mode number. I am pretty sure that last character being different is just an updated version. It is physically identical. Car it came out of even had the 6 CD changer in the trunk. I read someplace about changing the configuration and can't find where that was.
    Oct 2007
    Ruskin, Fl
    OK, just an update. I pressed and held the tune button (I think. I pressed everything) and now it displays all the same config info as the original radio. Only thing I need to figure out is if the subwoofer can be enabled on this unit.
    Are you sure the CV it came from had a factory sub? I think that's pretty rare...
    If there is a subwoofer connector on the back of the radio, then it should just work. I don't think there's any kind of config to turn the sub off or on.
    Exclamation
    I have the same part number radio .( see picture )
    It is not compatable with subwoofer , So i upgraded to audiophile cd-6 .
    SOLD MY MARAUDER .
    Mar 2003
    Las Vegas, NV (Henderson)
    Look at the button in the center of the radio just below the casette tape slot. RDS only on the button is a non-subwoofer enabled head unit. Marauders have RDS on the left side of the button and DSP on the right side of the same button that only has RDS on the Crown Vic/Marquis units. They will play, but not the subwoofer.
    1 of 111 Without Heated Seats
    6 CD Changer in Trunk
    Locking Lugs
    Trunk Organizer
    Marauder Side Emblems
    Rear Bumper Inserts
    Nephews: Blue w/Light Flint
    Born 02/05/03
    2011 of 7838
    Locking Lugs
    Trunk Organizer
    Factory Alarm
    Rear Bumper Inserts
    6705 of 7838 2003's
    Built Friday 02-07-2003
    Bought 09-10-2012
    #5 2003 DBP/Light Flint
    6741 of 7838 2003's
    Built Tuesday 02-11-2003
    Bought 05-06-14
    Sep 2010
    Western WA
    The last two digits are the key part in a Ford part number. All those numbers in the middle define what type of part it is, in this case a radio. The first 4 numbers define when it was designed. I'm betting if you take it back out and look in the connector for the subwoofer you will not find any pins in there.
    Quote Originally Posted by EMAS View Post
    That's what I was going to ask, why would it have a connector with pins if it was not subwoofer-enabled.
    Sep 2010
    Western WA
    Because they use the same case for lots of different radios and need something to plug the hole. Using the same connector without terminals is cheaper than designing and stocking a block off plate.
    Wouldn't the OP have noticed the lack of terminals when he went to plug in the subwoofer connector?
    Sep 2010
    Western WA
    If he looked down the hole but my guess is he didn't.
    Here is a page that describes and shows some of the different connectors Ford has used over the years.
    edit: whoops here is the link http://oem-auto-accessory.com/photo_page.html
    Here is a page with the back of a unit for a 2004 CV that shows the place for the subwoofer out but no terminals in it.
    http://oem-auto-accessory.com/BACK%2...20S%20SIZE.pdf
    Oct 2007
    Ruskin, Fl
    I missed that. The CV radio has just RDS on the button, not RDS and DSP. Oh well, it sounds almost as good. I have had no reception for almost 2 years, so I is sure better than what I had. Will the audiophile cd-6 just plug in?
    Yes and the sub will work.
    Thumbs up
    Yes this is the number you want 6L8T - 18C815 - FD
    SOLD MY MARAUDER .
  1. Alternate Radio Question
    By Hg M75 in forum Interior Electrical/Electronics
    Last Post: 05-28-2013, 05:26 AM
  2. FRS / GMRS Radio Question
    By MM2004 in forum The Lounge
    Last Post: 02-13-2013, 05:51 AM
  3. radio question.....
    By 4drpower in forum Community Discussion
    Last Post: 11-10-2010, 02:29 PM
  4. question about radio
    By ImpalaSlayer in forum Shop Talk
    Last Post: 09-21-2007, 05:19 PM
  5. Radio Question......
    By NOMARQUIS in forum The Lounge
    Last Post: 01-24-2005, 01:06 PM
