Closed: Nothing sells here.
Last edited by montazch; 09-02-2018 at 01:42 PM. Reason: Closing because nothing sells here.
2004 DTR Marauder - Mods in the works.
Born-05 January 2004
#1253 of a build of 3214
#400 of 980 manufactured in Dark Toreador Red
Wow! Checking my slush fund now... Wow!
Trade for blue marauder plus $7500 on your end
98 P71SOLD
Any additional machining needed or would it be a direct fit ?
That's right. "These Slugs" need to have the 4.6 punched out to a 5.0. Worth it for the extra torque.
lol, if the pistons are between 3.5685 and 3.5695, you sure as hell don't need a 3.7" bore. More like a 3.57x cylinder bore which is more realistic.
All I know guys is that I decided to go to a lower Compression to amp up my PSI's on the blower. So... that's why I have these extra slugs if anyone is interested. Cool.
isn't the stock bore 90.2mm/3.551"
I actually don't know but what is the dish depth of the stock motor?
If I understand description in post pistons for sale Dish vol is -11cc
Correct. The "For Sale" pistons are -11cc dish.
