I just did mine as well on the passenger side, replaced with a standard bolt, washer and nut. Works great now.
FYI, down in the door channel I found a half dozen old rivet flanges they had just dumped in there before sealing up the door. Saved the UAW Member making $70 an hour in salary and benefits the 10 seconds to carry them to the trash.
Remember, Quality is Job One at Ford.
