I’m guessing it is? Looks pretty stout!
Lucky catch! I'm surprised they weren't tarped.
Oshkosh doesn't tarp their military items, lived south of Oshkosh for over 12 years, saw prolly thousands of units on trucks plus they build for foreign armies as well, could get export.
Trilogy # 192 / T.S. 0012
I'd like one for commutes around the DC Beltway...is a 7.62 Minigun an option?
How about Prius seeking missiles?
It I'm not mistaken that is the new replacement for the HMMWVs. Right before I got out of the Army there was some joint services request for an updated troop vehicle and I think a baby MRAP looking truck was the winner.
2003 Mercury Marauder 300A
Former Owner: Joe Walsh
2015 Mustang GT PP
Guard Metallic Exterior
2018 F-150 King Ranch
2WD, 3.5 EcoBeast
