Results 1 to 15 of 28
Thread: Low brake pedal
    Mar 2010
    Myrtle Beach S.C.
    Low brake pedal
    My MM has a low brake pedal..Just like others that have posted this same condition,Pump the pedal twice and it's fine..I just had new rotors and pads installed.The first day,the pedal was fine.Next day and the pedal is low again.I'm going to buy the SS brake lines being sold by TCE..Will this fix the issue?After having the new brake lines installed,I figure that they'll need to be bled..Can any shop do this or do they need the machine for the ABS system?How much should this job cost??
    The SS lines won't fix a LOW pedal, but they will make the pedal feel more firm once it engages.
    Sounds like whoever did your brake job didn't bleed the system properly...I'd go back to them and tell them to make it right.
    You don't need a special machine unless you let the master cylinder run dry.
    Mar 2010
    Myrtle Beach S.C.
    Low brake pedal
    The pedal is firm.I just have to push it further than I would like.As I said,pump it once or twice and it's higher.This is exactly the way it was before the new rotors and pads.I replaced those because I did a pad slap previously and had a bumpy pedal from grooves in the rotors.I doubt a bleed was done.When replacing pads and rotors is a brake bleed needed?
    The brakes have had this condition for a very long time.They stop good.The pedal is firm.The problem is the that the pedal goes down lower than I want unless I pump it twice.I've seen this condition mentioned numerous time on this forum..Some say SS lines.Some say master cylinder.
    As stated the SS lines ill make the pedal rock-hard if the brakes are bled properly.
    I'd swap out the lines and gravity bleed the system.
    If the brake fluid is dirty, remove as much as you can with a turkey baster - I get the at the dollar store - replace with clean fresh fluid, open right rear bleeder screw and let it drain until you get clean fluid, then close the bleeder screw. Always check the master cylinder, make sure it ever gets empty. Do the same for the the left rear, right front and left front.
    Mar 2010
    Myrtle Beach S.C.
    Brakes
    Thanks for the info.My pedal is firm.The issue is the pedal is low.I have to push it further than I would like.Two pumps and the pedal is where I want it.Not a soft or spongy pedal issue....I have read others with the same issue.The only one I remember that fixed it,cut 1/4 inch of vacuum hose.
    I was asking if the SS brake lines would cure this.From the answers,it doesn't sound as if the lines are the problem..
    Buy lines and replace yours
    Problem was there before you had rotors replaced
    If it was the booster, no matter how many times you pumped the brakes, you wouldn't get the assistance from the booster. I.e. Pumping makes it better, then it's not the booster
    Mar 2010
    Myrtle Beach S.C.
    I'll do it.Thanks
    Quote Originally Posted by bugsyc View Post
    I'll do it.Thanks
    Make sure the emergency brakes are adjusted.
    As I have been down this road........ In my case the master cylinder had an internal leak, replaced it and the problem went away. It is possible that there is air in the system, if you can safely get your ABS to engage in a parking lot somewhere, afterwards, is the pedal better? If so, you need to bleed the system, their is air someplace.
    If that abs trick doesn't make the pedal feel better, then you are most likely looking at a master cylinder. Your parking brake is a separate system and has nothing to do with pedal feel.
    I always bleed my brakes after replacing pads or rotors, fluid gets old and contaminated, it does occasionally need changed.
    Trilogy # 192 / T.S. 0012
    Rockford
    I was in st. Louis a few weeks ago actually at for the July several guys that drove my car made that comment that my brake assist all the sudden fades.
    Now I'm looking into what you just described for a master cylinder or if anybody has suggestions I've been reading about the brake booster and all that.
    But I definitely have those symptoms
    Sent from my XT1096 using Tapatalk
    Mar 2010
    Myrtle Beach S.C.
    Have you tried bleeding them?Seems like the first and cheapest place to start.Let us know how you make out.I'll do the same..Hopefully that's what's up.
    Mar 2010
    Myrtle Beach S.C.
    Brakes still not great.
    I bled the brakes.It only made a slight improvement.I'm still not happy with them.Next step will be to replace the brake hoses with Todd's SS lines. I didn't mention that I have a line lock on the front brakes.I haven't really used it in years.I'm wondering if that is part of the issue? I'll check back when I put the new brake lines in...I tried pushing the brake pedal and then starting the car.There was no movement of the pedal on start up.Does that mean something?
    When the car is all put back together, put your eyeballs on the hose and have someone jam on the brake pedal
    Watch those hoses rubber hoses flex
    Yours is a 300a right? So no traction control?
    Mar 2010
    Myrtle Beach S.C.
    The car is all together now..Yes,300A.No traction control..Yep,new hoses are on the agenda.
    Low brake pedal
    All cars have a firmer pedal if pushed more than once. Are you positive you just haven't gotten to accustomed to the Charger's? Newer car, better refined.
    The line lock is just a check valve, unless it's leaking then rule it out.
  1. Crunchy Brake Pedal?
    By Vortech347 in forum Steering, Suspension & Brakes
    Last Post: 08-20-2010, 11:16 AM
  2. Low brake pedal
    By Matt In Detroit in forum Steering, Suspension & Brakes
    Last Post: 08-07-2010, 10:13 PM
  3. Noisy brake pedal?
    By khc3 in forum Steering, Suspension & Brakes
    Last Post: 07-25-2007, 03:33 PM
  4. Squeaking brake pedal
    By kdjlaw in forum Shop Talk
    Last Post: 06-21-2006, 05:28 PM
  5. Brake pedal travel
    By jcb100 in forum Shop Talk
    Last Post: 04-02-2004, 09:49 PM
