MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Suspension & Brakes
Suspension & Brakes Post your discussions about suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 09-28-2017, 10:09 AM
Chard Chard is offline
Member
Trader: (0)
Full Coilover Kit for MM
I'm planning on doing a full restore/improvement on the factory suspension on my MM. The idea is to go full coilover kit as i have done with my previous vehicles. Currently from what i read is most people go for the HQ Ridetech kit with the NAAKE/QA1 being a hit or miss.
This is where i get a bit confused, it seems Both kits only offer a front kit or am i not searching correctly.
Does any one have a full Front/Rear Coilover kit for the MM?
For a reference i have a 300A MM
  #2
Old 09-28-2017, 10:26 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (39)
Have you taken a look at your rear shock, or its placement?
  #3
Old 09-28-2017, 10:32 AM
Member
Trader: (0)
Quote:
Yes, what about it ??
  #4
Old 09-28-2017, 10:34 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
just use your air ride height adj. there ae no coilovers for the rear. it would need fabbed up to hold.
__________________
  #5
Old 09-28-2017, 10:42 AM
Member
Trader: (0)
I should of mentioned this in the original post, My MM is equipped with rear coils. not airbags
  #6
Old 09-28-2017, 11:53 AM
Weißbirke Plünderer
Trader: (11)
the present rear mounts are not rated, nor room for coilovers. custom job to make work
__________________
  #7
Old 09-28-2017, 11:55 AM
Lowndex's Avatar
Lowndex Lowndex is offline
Middle Age Crisis Member
Trader: (3)
Quote:
Please share pictures and details. You relocated control arm, moved shock, etc.
  #8
Old 09-28-2017, 12:33 PM
Member
Trader: (0)
I didn’t modify anything in the rear suspension. I bought the car like this. My idea was since it was a 300a it was a pre air suspension car.. but now I’m starting to think i may have been wrong this whole time
  #9
Old 09-28-2017, 02:05 PM
Weißbirke Plünderer
Trader: (11)
marauders were all rear air spring cars..someone switched them out to springs. rear coilovers ae not a bolt on option, will require fabrication
__________________
  #10
Old 09-28-2017, 05:26 PM
CoreyM75's Avatar
CoreyM75 CoreyM75 is offline
Senior Member
Trader: (3)
Quote:
While you're throwing money all over the place, maybe get someone to develop a un-poverty coil rear spring set up.
The op's car had the air suspension swapped out with coil springs. Doing such is commonly referred to as "poverty coils".
__________________
If a million people believe a foolish thing, it is still a foolish thing.
~ Anatole France
2004 DTR 54k, Dark Charcoal, heated seats, moonroof, trunk organizer.
Mods: K and N intake, Lido tune, Pro Guard rear bumper, stainless bumper inserts, res delete tips, misc
UncleLar's first DTR
2004 Ford Crown Victoria Sport 100k, black, Dark Charcoal, stock and a zero option car.
  #11
Old 09-28-2017, 08:29 PM
RF Overlord's Avatar
73 is the best number.
Trader: (2)
No such thing. All Marauders have RAS unless converted by a previous owner.
__________________
  #12
Old 09-29-2017, 07:32 AM
Member
Trader: (0)
Well, this is what i get for not doing a better research on these vehicles.. So i found the switch, the compressor and what seems to be the lines are still there. Well since now i know i can only get the front Coilover kit, ill be removing the rear coils and replacing them with the appropriate airbags and using the ride height adjuster to lower the rear end. With that in mind what brands do you guys recommend?
  #13
Old 09-29-2017, 08:21 AM
NorthShoreChiMM's Avatar
NorthShoreChiMM NorthShoreChiMM is offline
Mike
Trader: (0)
Get the suncore ones. Prob the best aftermarket bags out there
  #14
Old 09-29-2017, 01:56 PM
Trader: (2)
Not to create a war, but the Arnott Limo bags are also very good.
__________________
  #15
Old 09-29-2017, 02:44 PM
jaywish's Avatar
jaywish jaywish is offline
Senior Member
Trader: (0)
OEM air springs seem to still be available from a quick online look.
__________________
03 MM, DPB, Charcoal, 6disk, HS, organizer, spoiler, Z&M arms, silverstars, oil deflector, U-Hall Tranny pan.
89 GM LS Colony Park, Mods-> HO, ss duals, HPP 16" rims, 225-60-16, hella H4 & H1 headlights, large frame 3g alt, rear auto air shocks, hd springs, rear police sway, alum driveshaft, 99 front and 03+ rear brake upgrade, tranny cooler, posi, winter boots= Town Car rims, 215-65-16 Goodyear Ultra GW3 Snows, Kenwood speakers, 93CV stereo.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
KYB/Eaton vs Naake coilover kit Dobs Suspension & Brakes 29 04-16-2014 09:41 PM
i need a coilover spring! whitey Suspension & Brakes 10 12-01-2012 05:25 AM
coilover,lowering springs bigmerc281 Suspension & Brakes 9 11-06-2012 01:08 PM
For Sale Full set of OEM wheels plus full spare ctrlraven Marauder-specific Parts for Sale 5 09-10-2009 07:05 PM
coilover change out burt ragio Community Discussion 1 04-11-2008 10:57 AM
Powered by: vBulletin
