Results 1 to 13 of 13
Thread: Trilogy Alternator Wire Fail
    Houston
    The other night my battery light came on and the voltage dipped to about 10 volts. Pulled into a parking lot and discovered that the heat shrink on section of the alternator wire had vaporized! There was nothing left covering the wire coupling at all. To make matters worse, the coupling was also grounding to the alt bracket.
    The Trillogy kit has the alternator wire cut and lengthened. It uses two screw couplings to do this. (I bought my car after the Trillogy was installed.) They did have high quality heat shrink covering both of these connections at least. Apparently corrosion set into one of these so bad that only 8 strands were left to carry all of the current from the alternator. Well, that caused a LOT of HEAT to occur.
    I replaced the alt wire with a beefier pre-made battery cable and reduced the joint to only one coupling. Also liberally used dialectic grease in the connection. Sealed the joint with self sealing high temperature silicon wrap. My voltage with the engine running is better now than it ever was.
    Sharing for other Trillogy owners. Might be worth checking on your cars.
    2002 White F250 7.3 - Turbo
    Jun 2007
    Whitehall, PA
    That's what happened to my trilogy when I bought it in non-running condition. I only remember 1 splice..... When I rewired it, I got a splice block from Home Depot, put tons of dialectic grease around it and then shrink wrapped it.
    2003 DBP/LF - # 36 (sold)
    2003 DBP/LF - # 205 (sold)
    2004 Black - Trilogy #43
    2003 Black - shitbox (sold)
    2004 DTR - shitbox #2
    This has been happening for 10 years
    I always apply dielectric, then heat shrink then tape
    I can make up the correct length of 4 gauge wire with the appropriate terminals soldered on each end.
    I was jussstt about to say welcome to 2005!
    Builder Of Badassery
    Dec 2008
    South Carolina
    Yep a beefy ground is mandatory.
    Adopted 3/31/11. Sold
    03 300a black #1199
    TERMINATOR SWAP
    430rwhp. Done by mo's
    Aug 2007
    las vegas
    I'll take one, seriously.
    Quote Originally Posted by 03blackvegas View Post
    What color, how long (from terminal to terminal) and what stud diameter terminals on each end?
    I can also supply convoluted tubing.
    Aug 2007
    las vegas
    I'll check details this weekend, thanks for your response.
    Oct 2008
    Windsor
    yeah, just seeing that gives me the creep. you NEVER use that kind of cheap fix when dealing with a power wire, that could have easily set the car on fire let alone wipe out the ECU and/or the ALT.
    Port Charlotte, FL
    I installed my Trilogy myself and helped on a couple of others. I do not recall that type of connector in the Trilogy kit, and I don't see it in the install manual.
    Guess someone did that themselves, or as a repair after the swap.
    Corrosion sucks.
    04 Crown Victoria Sport
    1995 F150 4x2 4.9 5spd
    Aug 2007
    las vegas
    Quote Originally Posted by O's Fan Rich View Post
    Corrosion sucks.
    Actually, Corrosion eats.
  1. Wanted To Buy trilogy tensioner & alternator brackets
    By Comin' in Hot in forum Marauder Parts/Misc. Wanted
    Last Post: 11-05-2013, 12:58 AM
  2. Alternator pulley FAIL!
    By Mike M in forum Shop Talk
    Last Post: 09-14-2012, 12:43 PM
  3. High amp alternator that works with a Trilogy?
    By jasonblair in forum Shop Talk
    Last Post: 08-07-2012, 04:24 PM
  4. Alternator Power Wire
    By cougar9150 in forum Shop Talk
    Last Post: 12-14-2009, 02:30 PM
  5. Alternator Tool - Trilogy Owners?
    By magindat in forum Shop Talk
    Last Post: 03-06-2009, 12:17 PM
