Vortech Cold Weather - 25* Max Cold
"IMPORTANT COLD WEATHER INFORMATION
In order to achieve the low noise level of Vortech
superchargers, Vortech specifies manufacturing
procedures that call for minimal internal clearance.
These precise tolerances however are not
conducive to temperatures below 25° F. Therefore,
storing the vehicle in a heated garage and/or
employing the use of an engine block
heater/aftermarket engine blanket is required when
the vehicle is subjected to a "cold startup" in
ambient temperatures below 25° F. Failure to
comply with this may result in immediate
supercharger failure and invalidate the
supercharger warranty."
http://www.vortechsuperchargers.com/images/94.pdf
