Results 1 to 15 of 15
Thread: 2002 CV Sport $725? WASH DC
    Jun 2017
    Oxford, PA
    Not mine
    wondering...
    --did they offer this in 2002
    -why does a 120K mile single cam 4.6 need "a timing chain"?
    https://washingtondc.craigslist.org/doc/cto/d/laurel-2002-crown-victoria-sport/6787808260.html
    Jun 2008
    yes
    Ford TSB:
    FORD: 2000-2003 CROWN VICTORIA
    MERCURY: 2000-2003 GRAND MARQUIS
    ISSUE:
    Some 4.6L 2V engines may exhibit a grinding type noise from the timing chain area. This may be caused by excessive wear of the timing chain tensioner arms. The tensioner arm has an aluminum base with a nylon surface. Another indication of this condition may be fine nylon and/or aluminum particles present in the engine oil.
    ACTION:
    Inspect the timing chain and arms to determine if excessive wear exists. If this condition is present, replace the timing chains, tensioners and the tensioner arms. Refer to the following Service Information for details.
    SERVICE INFORMATION
    Refer to Workshop Manual Section 303-01A for correct replacement service procedures.
    If I lived closer, I'd be on this one, even if I don't buy his claim that it's faster than a Marauder.
    wow, great deal on the 02. Buddy down the street from my parents had a 02 and with a tune, exhaust, cold air kit and a converter. We did a 60 punch on the highway, ill be damned if i didnt get a hole shot of 1.5 cars and then he stayed right there and kept up.
    If that car was 350 miles or less away, it would be in my driveway the next day or same day weather permitting.
    02 has the old front suspension and a narrower rear axle. So you cannot slap marauder wheels on it because the foot print is different. 02 and older is still a cool car, that car has duals and air ride too.
    Any idea if its rusty?
    Oct 2008
    Massachusetts
    Not a bad deal, good engine swap candidate if it is as clean as it looks.
    May 2018
    Maryland
    I gave the guy a call and will be looking at it early next week. "ticking noise like a typewriter.." We'll see what she looks like.
    Easily could be a clogged oil squirter for the lash adjusters. RTV gets clogged in there if anyone did a sloppy job on a oil pan or timing cover.
    https://youtu.be/KCkBGDuw4sI
    Las Vegas, NV
    Looks like the foot well has been worn thru the mat and carpet.
    On the other hand you get a Snickers in the back seat.
    2003 Marauder 1907 of 7838
    Built 06/24/02 Bought 10/25/02 Sold 1/5/19
    Reinhart chip,stat,plugs
    McGard locks
    Mercury logo valve/plate bolt caps
    Bob White black reflective letters
    Pioneer AVH-X2500BT
    Kicker 10" sub and 250 watt amp
    Gods Head spinners by Jerry
    May 2018
    Maryland
    Sooo, I looked at this one. I'm not sure what is left on it that is worth $750, maybe the wheels, gauge cluster, column cover, and console with broken latch....
    All of the wheel openings have been cut and rolled by a beaver or a monkey with an angle grinder. The lower jamb/C-pillars have been hit with a sledge hammer and the front and rear bumpers have been cut. Must have had some gigantic wheels on it at one time. Dents in every panel and the spoiler is on with self tapping sheet metal screws that are poking out the top. Console latch is broken and the cup holders are cracked. Seller seems like a nice guy and has only owned it for a year, but this car has been abused at some point in it life.
    What do you all think- let someone else save it, or grab it and part the few good things left?
    May 2018
    Maryland
    more pictures
    May 2018
    Maryland
    last few, unfortunately my phone died before I could get any more.
    May 2018
    Maryland
    original ad pictures
    Jun 2017
    Oxford, PA
    Probably had "wagon wheels" on it at one time, that means the front suspension could probably use attention. On the other hand, a used up P71 is probably more expensive, so could this be a winter car or DD for someone?
    once a car gets run down to a certain point it seems like there's not enough new parts and money in the whole world to make it factory fresh again.
    I'd pass on it if just scavenging for parts...
    Sports are fairly rare, so it's a shame someone let this one get so bad, but for $725 it's certainly worth doing the tensioners and keeping as a DD.
    Jun 2008
    I still think it looks good for the ask price...
    May 2018
    Maryland
    Sounds like the consensus is still a driver. I'm short on space so adding a third panther is out of the question. It's worse than both of mine, so if anyone wants it, I can set it up for you, I think I still have another day for first right of refusal.
  1. Wanted To Buy 2002 Crown Vic SPORT
    By LSCR351 in forum Other Cars Wanted
    Last Post: 10-27-2012, 10:20 PM
  2. Wanted To Buy 2002 CV LX-sport or GM LS-E wheels
    By EMAS in forum Other Parts/Misc. Wanted
    Last Post: 01-17-2012, 10:55 PM
  3. For Sale 2002 Crown Vic LX SPORT
    By NIGHTHAWK in forum Other Cars for Sale
    Last Post: 05-21-2010, 05:19 AM
  4. 2002 Crown Vic LX Sport For Sale
    By CROWNMARAUDER in forum Other Cars for Sale
    Last Post: 04-26-2009, 06:13 PM
  5. 2002 LX Sport
    By Wagonmaster in forum Community Discussion
    Last Post: 11-14-2005, 01:18 AM
