Results 1 to 15 of 18
Thread: Base tune or use Lidio's tune for break in?
    Nov 2007
    NorCal
    Question Base tune or use Lidio's tune for break in?
    Hey all,
    When the motor is installed do you think I am going to need a special base tune for break in (500 miles) or can I just used the one loaded up by Lidio?
    Opinions appreciated!
    Cheers!
    2003 Mercury Marauder 300A
    FRPP BOSS50 Block w/MMR 900S Stroker 5.3L DOHC 324ci 10:1cr - (321rwhp/360.5rwtq) - Tuned by AED
    2006 Ford Mustang GT
    FRPP FR3 Handling Pack|FRPP X Pipe w/GTA Exhaust|Steeda CAI|Hurst Shifter
    (289rwhp/307rwtq)
    2003 Chevrolet Suburban 2500 LQ4 6.0L LT 4WD
    Cognito leveling Kit, Fox 2.0, BFG KOA2 Radial All Terrains, Magnaflow, K&N and 4.10 gears
    change your name back, your confusing me
    Nov 2007
    NorCal
    NO....Davie boy...I like this one better! New motor new name...lol
    (289rwhp/307rwtq)
    HA! sorry i cant help you, hopefully the big bore guys will chime in
    Nov 2007
    NorCal
    Have I mentioned I hate you lately Dave...lol
    (289rwhp/307rwtq)
    i hate YOU. i want that engine!!
    Feb 2009
    Upstate NY
    I'd talk to MMR about it. I think you should use regular dino oil for the first 500, this will let engine run hotter and let the rings seat properly. Take it easy, no burnouts, don't drive the same speed, don't let her overheat but do get it up to full operating temp everytime you start it. Your old tune should work fine. After it's broken in then get a dynotune. This would be the old school way. Others will say fill it up with synthetic and take it to the drags. Again I'd ask MMR. Can you post the dyno sheet you got from MMR? All of their engines are suppose to come with one. BTW very nice!
    03 300A - Number 1727
    As for the engine, it may not run with the tunes you have. Cams, displacement, injectors, MAF changes or just the cams & displacement?
    As for the name change, it would really be hard to keep up if I (or Zack, or a few others) changed screen names every time we changed engines/displacement/setup. Name changes are for trying to hide (i.e. diabolical/AJ).
    Feb 2009
    Upstate NY
    Duh, injectors will be a big item, 24 to 39 is a big change. Fordnut is right, you'll need a new tune.
    Lehigh Valley, PA
    welcome to the site noob
    I highly doubt that a lidio canned tune will work for a 5.0L built motor.... Just get a dyno tune, why even ask?
    2063/3214
    5377/7838
    Nov 2007
    NorCal
    Because I am cheap and don't want to wait...for them to tune...lol Also, just not afraid to ask because I don't know everything......and no one else does either....
    BTW, Its a 5.3L BB/S....lol
    (289rwhp/307rwtq)
    Nov 2007
    NorCal
    Quote Originally Posted by babbage View Post
    okie dokie!
    (289rwhp/307rwtq)
    Nov 2007
    NorCal
    Yeah...my logins for all the other sites are the new one so didnt want to have to remember to many log ins....
    But yeah thanks for the feed back all.....Ill go back to work now!
    (289rwhp/307rwtq)
    Jun 2005
    East Lansing, MI
    DO whatever your builder tells you is my advice. As for me, I beat its A@% from about day 1
    11.90 @ 117.5mph on 93 octane
    Igziabeher
    This is an interesting thread. I am not sure how you got far enough to get an MMR motor and then want to cheap out on a tune. Oh well...
    But yeah to answer your question, you should get a custom Dyno tune. Your car has too many changes to it to use a base tune whether factory or otherwise.
    Good luck with your build.
    96 GM HPP 206K mi.(chassis), Tuned by Manny at HPP, 76mm DBB PT, SQV BOV, Accufab TB/UP, Tial 44mm WG, 3" Intake and 3" Single Exhaust piping, PI Intake, PI Cams, MMR Stainless Valves, Manley Springs, P&P PI Heads, Forged Rods and Pistons, 90mm Lightening MAF and injectors (42lbs), 255 Walbro, BOC Trans, BOC Stage II TC 3,000 stall, 3.73, Trac-Loc, Cobra Carbon Clutches, AMMX driveshaft, SCT Xcal II J-Tune, Transmission cooler, PowerSlot Brakes, ENS front control arm bushings, Addco Front and Rear Swaybars, Poly Endlinks and Clamps, Front and Rear Bilstien Shocks, F/R PI springs, Rear ENS Control Arm Bushings, custom structural re-enforcement(stabilizer bar mounts and lower control arm mounts, among other spots), Custom Boxed Lower Rear Control Arms, Kenwood HU, Alpine Type R 5X7's, Kicker Comp 6X9's,Alpine 4X50, Crunch 1100 subwoofer Amp, Image Dynamics 12" subwoofer, Yellow Top
  1. Replies: 5
    Last Post: 03-12-2009, 05:58 PM
  2. Base tune for blower
    By blazen71 in forum Tuning
    Last Post: 09-10-2008, 06:42 PM
  3. Replies: 3
    Last Post: 07-14-2007, 02:19 PM
  4. Lidio's Tune
    By KillJoy in forum Alternative Automotive
    Last Post: 02-01-2006, 10:04 PM
