ProCharger P-1SC FIT #31 / 9 lbs. Boost
HPX Blow thru MAF 462 HP / 423 Torque
Engine
4.6L 32 Valve D.O.H.C V8 / 158K miles
Accufab Dual 60 MM Throttle Body / New O2 Sensors / Granatelli COP Connectors
Rear Engine cooling Mod / Custom Powder Coated Upper Intake
Exhaust
Stainless Works Long tube Headers
18 inch Magnaflow Performance Mufflers
Custom Removable H Pipe / MEGS Resonator delete tips
Transmission
Art Car L2 Transmission Upgrade / Rear bearing Tail shaft Lube
Precision Industries Stallion 3000 Stall Torque Converter
Aluminum Finned Deep Pan / MMX Drive Shaft
Suspension
Addco Front & Rear Sway Bars
Replaced Upper control arms and ball joints / Front Coils cut 1 turn
Rear End
Sparta Performance Rear Control Arms / T/A Rear end Girdle / 3.55 stock Gears
Adjustable Rear Air Suspension
Brakes
Pro Stop Platinum Ceramic Brake pads Front & Rear
Replaced Front Rotors / Vacuum Reserve Canister
KVR Stainless Steel Braided Brake lines
Husrt Line Lock
Wheels
Konig 18 inch x 7.5 inch / Goodyear Eagle GT 235/50 ZR 18
Konig 20 inch x 10 inch / Delinte DL4000 315/35 ZR 20 XL
Gorilla All around Wheel Locks / Valve Stem locks
Interior
2 Dual Aeroforce Scan Gauges w/ real oil sending unit
Kenny Brown Deal Pedal / Tinted Windows
Pristine Stock Marauder Floor Mats / Custom trunk Lighting
Exterior
2 Tone Paint Scheme / Stainless steel Bumper Inserts / Proguard Air Deflector
Replaced Head lights / Behind Grill Mounted Fog Lights / Custom F & R Badges
Martyo Fender badges / Limited edition Badges
Stereo
Pioneer AVIC-D3
Pioneer TS-D681R Kevlar 6 x 8’s
Linear Power 500.2 Watts / 1F Capacitor / Digital Design 9515b 15 inch Subwoofer
Audio Control Epicenter / Audio Control Eqx
Accessories
Galaxy DX 88HL 40 Channel CB radio
Astatic 636L Power mike / Wilson 1000 Magnetic mount Antenna
