Results 1 to 11 of 11
Thread: Engine Computer PCM ECM ECU 2003
    May 2013
    Saudi Arabia
    Smile Engine Computer PCM ECM ECU 2003
    Wanted to buy a 2003 PCM with code (BMD0)
    Mine is burnt so I don't know if the 2004 well work or not? or maybe another code well work or not?
    PM me if you have any offer guys.
    Thanks.
    Eaton M112 Supercharger
    Intercooler
    Lower intake plenum
    Coolant Intake Manifold
    TB Intake Plenum
    Throttle Body
    Cobra air intake tube
    Accelerator cable bracket
    Fuel rails
    39lb. injectors
    Cobra heat exchanger
    lower Metco pulley with hub
    Intercooler reservoir
    90mm Lightning MAF
    MAF to filter adapter plate
    Conical air filter
    Custom Gortch Brackets
    Heat Exchanger brackets
    Intercooler pump
    Intercooler pump bracket
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    It's best to have a pcm with a matching key
    Sending pm
    Hiram, Georgia
    Sending pm
    Why’s that?
    If you buy a pcm with the cylinder and matching key, then you dont have to pay someone to match a key to the pcm.
    Here they wanted 250.00 to come to my house and program a key to a marauder with lost keys.
    With matched key and cylinder, dont have to pay to get it towed to a shop to flash the key to the pcm.
    May 2013
    Saudi Arabia
    Sending pm
    PM replayed..
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Hiram, Georgia
    That would require PATS.
    We ain’t got time for that.
    May 2013
    Saudi Arabia
    Is it hard to switch it off?
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    Hiram, Georgia
    Quote Originally Posted by BeeDamn View Post
    Not for me.
    Don’t worry yourself over it.
    May 2013
    Saudi Arabia
    Thank you so much
    Intercooler
    Lower intake plenum
    TB Intake Plenum
    Throttle Body
    Fuel rails
    39lb. injectors
    90mm Lightning MAF
    Conical air filter
    Intercooler pump
    Ribbed idler pulley
    Belt tensioner
    Alternator Pulley
    Fuel Pump
    EGR delete kit
    New accessory belt
    Cooling tube
    IAT sensor
    I had that crap turned off like eight years ago after it left me stranded one night..
    Good ridden!
  1. 2004 Marauder computer in 2003 Marauder
    By Themarauderguy in forum Shop Talk
    Last Post: 09-08-2017, 10:03 AM
  2. need new engine for my 2003
    By judy in forum Shop Talk
    Last Post: 09-22-2014, 07:38 PM
  3. Engine Control Computer
    By williamsd123 in forum Shop Talk
    Last Post: 06-14-2011, 06:06 PM
  4. For Sale 2003 Marauder Engine F/S
    By SmokdMercRauder in forum Marauder-specific Parts for Sale
    Last Post: 10-26-2009, 06:21 PM
  5. 2003 Cobra 4.6L engine
    By Svashtar in forum Shop Talk
    Last Post: 01-18-2005, 09:20 PM
