Originally Posted by
CobraSVT657
Decided to sell the Eaton setup I was going to put on the 93 Cobra in favor of a 331ci turbo setup.
Posi ported eaton (stock pullied) only startup time since port. Zero miles
Welded and ported Plenum
Ported TB
intercooler
lower intake manifold w/ water outlet for intercooler
IAT2 with pigtail
throttle cable bracket
$1200.00+S/H
03/04 Cobra Engine harness $150 shipped
60# injectors with harness adapters. start up time only. $300 shipped
SCT BA2600 MAF. start up time only. $250 shipped
LFP 2# Lower hub and ring. start up time only $200 shipped
03/04 Cobra exhaust manifolds with modified off road X pipe for Marauder. $200+S/H
AutoMeter column gauge pod with Ultra-Lite Boost gauge 0 miles $75 shipped
03/04 Cobra stock expansion res for intercooler. $50 shipped
Auburn 31 spline diff for 8.8. Was in my mustang 2 months before switching to a spool. $200+S/H
OK - Give me the bottom line on what I'll need for the S/C swap from the parts you've noted above.
Thanks!
Mark
