Just ordered my new HID projector headlights and LED fog lights from Panther Lights.
Man those are really clean like the God Head logo on them. How much are they?
There are so many variables involved:
* buying new headlights or retrofitting the ones you have now?
* which HID ballast are you choosing? 35 or 55 watt?
* Which relay are you buying: standard or Cannbus?
* Buying Halo light rings?
Also, as Panther Lights is not an official vendor, it is best you contact Kevin on Facebook, Panther Lights.
It would be really neat if you could project the God's Head like Batman!
To avoid head on collisions recc a headlight alignment.
A lot. With the halo ring surround and demon eyes, D2S kit, marauder gods head etching, from 600 to 800, (thats retrofitting current housings, add 250-300 for aftermarket housings). Its very cool and you could see everything from your house to the moon with the lights he provides. Ive messaged him on fb, very professional and answered all my questions.
That’s crazy numbers considering it’s probably more than 10% of most Marauder’s values and 20% or more for most crown Vic’s... Obviously there is exceptions to that rule.
I’ll keep my candles..
The last person I would expect that argument from, how much is invested between your fenders?!
Kidding of course, that’s a ton of money for headlights and your argument is certainly valid considering most Marauder owners are now like 5th plus owners and bought the car for cheap.
The estimated numbers that were quoted up top were including the best projector kit I offer, as well as all the extras like Bluetooth controlled halos and demon eyes, and the etched lenses.
A basic HID projector build will cost $400. That includes the HID kit as well. The only catch to that is I would need the housings to work with, or money provided so I can order a set.
I apologize for not adding that the quality looks outstanding, and I’m quite sure you aren’t making near enough on them.
Very true. But after fabricating or paying absolute top dollar for everything on my car I’ve treated myself to mass produced F150’s! After the millions of choices of quality parts on the cheap available for it, I have lost all interest in the car anymore.
No matter my opinion, I appreciate his effort in providing options for other members here who haven’t dived down the rabbit hole quite yet.
The advantage of Panther Lights is the number of customers and positive reviews. Kevin's work on the custom mounting brackets pays off with a very stable HID projector lens mount and LED fog lights mount. The end results is like it was made for the car.
Like anything else, it comes down to budget, time (yours or theirs) and what you value.
I hear ya' brother!
I'm eyeballing a new F150 STX Ecoboost 10 speed and have already started looking at ALL the aftermarket stuff available for it!
I feel like a kid in a candystore!
Even the Fusion Sport has a bunch of aftermarket parts available.
Sorry to the OP for the thread Hijack!....
Trilogy # 192 / T.S. 0012
