Results 1 to 7 of 7
Thread: A/C issue?
    May 2009
    Moreau Island
    Question A/C issue?
    Getting a periodic whooshing sound when A/C is on. Doesn't sound normal. Thinking the A/C coolant level might be low and needs a re-charge. Am I thinking in the right direction?
    Thanks
    Thanks
    If the R134A is low you'd hear the compressor cycling on & off alot.
    I've never heard of a whooshing sound before. Maybe debris caught in the system?
    May 2009
    Moreau Island
    Maybe whooshing is the wrong term. Sucking air or pushing air. Is there away to measure how much A/C coolant is in the system w/o cycling it all out on an A/C recovery machine?
    No, but a competent tech can put their gauges on the system and see if the pressures are correct.
    This is typically what a tech would or should do:
    https://www.yourmechanic.com/article...em-in-your-car
    Eric, when and where are you hearing this sound?
    May 2009
    Moreau Island
    Sounds like its coming through the A/C vents, for sure in front of me when the A/C is on, driving. I should also preface this is in my DD not the MM. Just thought this might be a common A/C issue.
    The only common "whooshing" sound I can think of is when the cowl and evaporator ducting get full of water due to a clogged drain flap just behind the passenger wheel-well liner. Had that on my 2000 GMQ.
  1. LCM issue or wiper board issue? Video included
    By Turbov6Bryan in forum Shop Talk
    Last Post: 05-25-2016, 12:00 PM
  2. PATS issue? LCM issue? Help me diagnose
    By Mebot in forum Shop Talk
    Last Post: 04-13-2015, 06:34 PM
  3. RAS issue
    By RF Overlord in forum Steering, Suspension & Brakes
    Last Post: 07-21-2014, 05:40 AM
  4. New Issue?
    By Dre1842 in forum Steering, Suspension & Brakes
    Last Post: 10-17-2013, 08:15 AM
  5. still an issue...
    By fusion1027 in forum Shop Talk
    Last Post: 01-30-2005, 12:01 AM
