DONE!!!
Pix and vid coming soon
DONE!!!
Well damn you finished before I did....how was the install for you??
Smoked 2003 300A Black MM, Avic D3, 6k HID's, Eaton conversion, J-Mod, JBA Stainless Ceramic Coated shorties, Modified Bassani X-pipe, flowmaster Super 44's,stock tips, Lowered and a big ol' grin Best ET 12.2 @111 on street tires...
91 Viper Red Gt, 6 point cage, old setup-kenne bell 14psi best ET 11.20's @ 126.xx spinning.. New setup- On3 turbo kit, race intercooler, 348 stroker boss block,80lb injectors, 2 step, Meth Injected Snow Stage 2kit, AFR 185's, Tremec 600, Fidanza 4.3 clutch blah blah blah....
more hiccups than a newborn....but its done. the install was actually rather simple, but every shortcut i tried to take backfired. Take your time
Yea.. I've definately learned about taking time and being patient...Thats what I've been doing....I feel ya on the hic ups.What did you do for your crossover tube?
i brought mine out past the blower belt. some people dont like it that way, but i love it. it still looks neat and there is almost NO welding necessary (unless you're doing the cooling mod). i just had tabs welded onto my tubes so they can be secured into the heads.
I guess, technically...this would make me #11 and you #12...right? BTW I started this project nearly 4 wks ago.......my tuning shop were bein A-holes and had my car sitting in a parking lot 4 10 days before i even got a tune to start the damn thing.
lol I know right... 11- 12 idk...did you run a BAP and GT pump?? You running stock exhaust??
yep. 40a BAP, GT-40 pump, 39lbs injectors, stock manifolds with super 44 mufflers. BTW does your alt bracket touch your water pump?
No it doesn't.. does yours??
it did until i grinded it down. the bracket he sent me musta been a little bit thicker. i was jus gonna warn u, but it sounds like yours is good.
are u runnin a BAP?
and those are the grotch brackets??
where did mount you i/c pump?? I havent got to that part yet..I got mine with the cobra bracket also..
congrats man cant wait for them pics
A legend quote a True Ride can not be no Rider without a Marauder
Finally Eatonized by ZackZillaaaaaaaaaaa!
Cardomain link: http://www.CarDomain.com/ride/3380944
A bank is a place that will lend you money if you can prove that you don't need it
