Air Filters OEM + K&N
Selling the OEM 'For Marauder Only' FORD/Mann Air Filter that I pulled out of my airbox with less than 200 miles on it.
Perfect for the concours correct Marauder restoration....
$55 shipped in continental US.
______________________________ ______________________________ _
K&N Filter is SOLD!!!
Reason: Sold K&N Filter
